cgal-discuss - Re: [cgal-discuss] Re: Surface remeshing using mesh generation
  • To:
  • Subject: Re: [cgal-discuss] Re: Surface remeshing using mesh generation
  • Date: Wed, 14 Mar 2012 15:20:50 +0100
On 14/03/2012 14:54, Zohar wrote:
First, I solved my inside condition bug:
http://cgal-discuss.949826.n4.nabble.com/Determine-if-a-point-is-interior-or-exterior-to-a-Polyhedron-3-td4466730.html#a4471850
Andreas,
The perturbation is really crucial for the closest point, else it doesn't
work.
I ran the algorithm, shooting one test ray for each vertex, on a 3k faces
model, resulting in a new 8.3k faces model.
With random ray it took 20 seconds, and with a ray to the closest point it
took 23 seconds.
It took me a few seconds to consider why: The random ray can miss the model
altogether for outside points ;) .
You should also have grid points outside the object.
andreas
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Surface-remeshing-using-mesh-generation-tp4471479p4471885.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
