cgal-discuss - [cgal-discuss] Re: How to calculate area of difference of two polygons?
  • To:
  • Subject: [cgal-discuss] Re: How to calculate area of difference of two polygons?
  • Date: Sun, 18 Mar 2012 00:58:09 -0700 (PDT)
You should have for each curve a begin() and end() to iterate the points.
These points you can insert to a new polygon and call the area function.
Post a full test program for further help.
Alternatively you can intersect the two polygons with arrangement_2, and for
each cell in the arrangement check if it is inside or outside each poly, and
do you bool operation accordingly.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-calculate-area-of-difference-of-two-polygons-tp4466197p4481788.html
