- To:
- Subject: [cgal-discuss] Re: Finding intersection segment
- Date: Tue, 20 Mar 2012 03:53:53 -0700 (PDT)
Zohar wrote
> 1. You must use Exact_predicates_exact_constructions_kernel
> 2. The assigned handle for assign() should be const. In this case the
> segment handle.
Thanks!
1. What am I to do if the example already uses
Exact_predicates_inexact_constructions_kernel? Can I use two different
kernels in the same example?
2. This additional code basically came from here:
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/STL_Extension_ref/Class_Object.html
. In my case all the definitions look the same, but I never get inside cycle
"if (assign(seg, obj)){}"..
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Finding-intersection-segment-tp4488033p4488342.html
- [cgal-discuss] Finding intersection segment, Oleg, 03/20/2012
- [cgal-discuss] Re: Finding intersection segment, Zohar, 03/20/2012
- [cgal-discuss] Re: Finding intersection segment, Oleg, 03/20/2012
- [cgal-discuss] Finding intersection segment, Sebastien Loriot (GeometryFactory), 03/20/2012
- [cgal-discuss] Re: Finding intersection segment, Oleg, 03/21/2012
- [cgal-discuss] Re: Finding intersection segment, Zohar, 03/21/2012
- Re: [cgal-discuss] Re: Finding intersection segment, Laurent Rineau (GeometryFactory), 03/21/2012
