- To:
- Subject: [cgal-discuss] Vector_3 and Point_3 from another library: code example
- Date: Mon, 26 Mar 2012 22:32:23 +0200
Code example of my last question:
namespace OtherLib
template <class K_, class K_Base>
class OtherLib_Kernel_base
: public K_Base::template Base<K_>::Type
typedef typename K_Base::template Base<K_>::Type OldK;
public:
typedef K_ Kernel;
typedef OtherLib::point Point_3;
typedef OtherLib::vector Vector_3;
template <class FT_>
struct OtherLib_Kernel_Cartesian
: public CGAL::Type_equality_wrapper<
OtherLib_Kernel_base<OtherLib_Kernel_Cartesian<FT_>,
CGAL::Cartesian<FT_> >,
OtherLib_Kernel_Cartesian<FT_> >
} // end namespace OtherLib
Is this sufficient for Polyhedron_3 to work with the "OtherLib" library?
Details:
If i understand this correctly, I'm defining a completely generic wrapper to
any kernel, by templating the OtherLib_Kernel_Base with K_base, and then I'm
using the wrapper to prescribe the Cartesian kernel. Something like a
specialization of a template class, where OtherLib_Cartesian_Kernel is just a
"type instance" of OtherLib_Kernel_base?
I have visited Type_equality_wrapper.h, and found this:
template < typename K_base, typename Kernel_ >
struct Type_equality_wrapper
: public K_base
typedef K_base Kernel_base;
#define CGAL_Kernel_obj(X) typedef CGAL::X<Kernel_> X;
#include <CGAL/Kernel/interface_macros.h>
// Undocumented stuff.
typedef CGAL::Conic_2<Kernel_> Conic_2;
typedef CGAL::Aff_transformation_2<Kernel_> Aff_transformation_2;
typedef CGAL::Aff_transformation_3<Kernel_> Aff_transformation_3;
which led me to interface_macros.h, which in turn made me stop. (The huge
list of of predicates are there... and other func objects) :) What does this
do exactly and how? Where can I find info on the wrapper? It's the last step
that I don't understand from my example above....
Tomislav
- [cgal-discuss] Vector_3 and Point_3 from another library: code example, Tomislav Maric, 03/26/2012
