[cgal-discuss] Bug report: CGAL installation doesn't detect eigen lib on windows
- To:
- Subject: [cgal-discuss] Bug report: CGAL installation doesn't detect eigen lib on windows
- Date: Tue, 27 Mar 2012 08:24:44 -0700 (PDT)
Hi,
Following:
http://cgal-discuss.949826.n4.nabble.com/Tutorial-Patch-cmake-for-visual-studio-and-eigen-or-any-other-platform-and-library-td4479845.html
Windows 7 x64, cgal 4, eigen 3.1.0-alpha2
1. I extracted the contents of the eigen zip into
c:\prj-external-libs\eigen-eigen\ (no installation). This is the main folder
that I also add to my include path, which has the Eigen source dir, i.e.
contains a file: c:\prj-external-libs\eigen-eigen\Eigen\core
2. Using cmake-gui to install cgal, I added a variable (also tried with env
var) EIGEN3_INCLUDE_DIR that is set to c:\prj-external-libs\eigen-eigen\.
3. Pressing on the configure button, I get the following warning:
Configuring demo in
C:/prj-external-libs/CGAL-4.0-x64/demo/Surface_reconstruction_points_3
Could NOT find Eigen3 (missing: EIGEN3_INCLUDE_DIR EIGEN3_VERSION_OK)
(Required is at least version "3.0.91")
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-report-CGAL-installation-doesn-t-detect-eigen-lib-on-windows-tp4509173p4509173.html
- [cgal-discuss] Bug report: CGAL installation doesn't detect eigen lib on windows, Zohar, 03/27/2012
- Re: [cgal-discuss] Bug report: CGAL installation doesn't detect eigen lib on windows, Laurent Rineau (GeometryFactory), 03/28/2012
- Re: [cgal-discuss] Bug report: CGAL installation doesn't detect eigen lib on windows, Zohar Levi, 03/28/2012
