cgal-discuss - Re: [cgal-discuss] Interval Skip List bug?
  • To:
  • Subject: Re: [cgal-discuss] Interval Skip List bug?
  • Date: Tue, 27 Mar 2012 12:34:24 -0500
Ping?
On 03/21/2012 03:31 PM, mrj10 wrote:
I was looking at Interval_skip_list.h and noticed what I think might be a bug
in adjustMarkersOnDelete(). Many places in the code need to do special-case
check to see if the source or sink of an ISL edge is the ISL header or
footer, but this check is not done in the if statement on line 860 (in CGAL
4.0). The check is currently:
if(x->forward[i]==0 ||
!m->getInterval()->contains_interval(update[i]->key, x->forward[i]->key))
newDemoted.insert(m->getInterval());
If update[i] is the header, update[i]->key will be garbage (we don't
initialize the header's key in the ISL constructor), so the
contains_interval() call may do something unexpected. It seems like the
check should be:
isHeader(update[i]) ||
The implementation is very clever in other places, so it's entirely possible
I may have missed an invariant that makes this check unnecessary, but I've
run into bugs where edges from the header have markers on them, and they
appear to be caused by a bad result from this check.
Best,
Matt
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Interval-Skip-List-bug-tp4493660p4493660.html
