cgal-discuss - [cgal-discuss] Re: Problem on CGAL Polygon_2 Intersection
  • To:
  • Subject: [cgal-discuss] Re: Problem on CGAL Polygon_2 Intersection
  • Date: Wed, 28 Mar 2012 01:09:40 -0700 (PDT)
Ok, got it. Thank you Sebastien and Efi.
On Wed, Mar 28, 2012 at 4:06 PM, Efi Fogel [via cgal-discuss] <[hidden email]> wrote:
The intersection computation must be used with an exact-predicate-exact-construction kernel. There is no other way.
We are working on fixing the code so that the predicate do_intersect() can be used with an exact-predicate-inexact-construction kernel, but there is no time frame yet.
I doubt there is a difference between the versions and, even if there is it's irrelevant.
On Wed, Mar 28, 2012 at 9:28 AM, Sebastien Loriot (GeometryFactory) <[hidden email]> wrote:
On 03/28/2012 05:20 AM, kyewong wrote:
Just one more thing too add:
I tested both CGAL 3.8 and CGAL 4.0, and found that this problem is much
more severe in 4.0 than in 3.8.
What do you mean?
Sebastien.
I sincerely hope that this problem could be solved soon since it brings me
lots of troubles (for example, using
Exact_predicates_exact_constructions_kernel will make the computation quite
slow and cause a lot of changes to existing code).
Thanks!
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Problem-on-CGAL-Polygon-2-Intersection-tp4507862p4511240.html
If you reply to this email, your message will be added to the discussion below:
http://cgal-discuss.949826.n4.nabble.com/Problem-on-CGAL-Polygon-2-Intersection-tp4507862p4511628.html
To start a new topic under cgal-discuss, email [hidden email]
To unsubscribe from cgal-discuss, click here.
NAML
Kai WANG
View this message in context: Re: Problem on CGAL Polygon_2 Intersection
