- To:
- Subject: [cgal-discuss] Example: Convert polyhedron from one kernel to another
- Date: Wed, 28 Mar 2012 22:15:36 -0700 (PDT)
This is a code snippet which I found in the examples, and should be in the
faq, doc, or a new page of useful cgal utils. Hopefully it would come up by
google:
// Can be used to convert polyhedron from exact to inexact and vice-versa
template <class Polyhedron_input,
class Polyhedron_output>
struct Copy_polyhedron_to
: public CGAL::Modifier_base<typename Polyhedron_output::HalfedgeDS>
Copy_polyhedron_to(const Polyhedron_input& in_poly)
: in_poly(in_poly) {}
void operator()(typename Polyhedron_output::HalfedgeDS& out_hds)
typedef typename Polyhedron_output::HalfedgeDS Output_HDS;
typedef typename Polyhedron_input::HalfedgeDS Input_HDS;
CGAL::Polyhedron_incremental_builder_3<Output_HDS>
builder(out_hds);
typedef typename Polyhedron_input::Vertex_const_iterator
Vertex_const_iterator;
typedef typename Polyhedron_input::Facet_const_iterator
Facet_const_iterator;
typedef typename
Polyhedron_input::Halfedge_around_facet_const_circulator
HFCC;
builder.begin_surface(in_poly.size_of_vertices(),
in_poly.size_of_facets(),
in_poly.size_of_halfedges());
for(Vertex_const_iterator
vi = in_poly.vertices_begin(), end =
in_poly.vertices_end();
vi != end ; ++vi)
typename Polyhedron_output::Point_3
p(::CGAL::to_double(
vi->point().x()),
::CGAL::to_double( vi->point().y()),
::CGAL::to_double( vi->point().z()));
builder.add_vertex(p);
typedef CGAL::Inverse_index<Vertex_const_iterator> Index;
Index index( in_poly.vertices_begin(),
in_poly.vertices_end());
for(Facet_const_iterator
fi = in_poly.facets_begin(), end =
in_poly.facets_end();
fi != end; ++fi)
HFCC hc = fi->facet_begin();
HFCC hc_end = hc;
builder.begin_facet ();
do {
builder.add_vertex_to_facet(index[hc->vertex()]);
++hc;
} while( hc != hc_end);
builder.end_facet();
builder.end_surface();
} // end operator()(..)
private:
const Polyhedron_input& in_poly;
}; // end Copy_polyhedron_to<>
template <class Poly_B, class Poly_A>
void poly_copy(Poly_B& poly_b, const Poly_A& poly_a)
poly_b.clear();
Copy_polyhedron_to<Poly_A, Poly_B> modifier(poly_a);
poly_b.delegate(modifier);
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Example-Convert-polyhedron-from-one-kernel-to-another-tp4514497p4514497.html
- [cgal-discuss] Example: Convert polyhedron from one kernel to another, Zohar, 03/29/2012
