cgal-discuss - Re: [cgal-discuss] Re: New to CGAL
  • To:
  • Subject: Re: [cgal-discuss] Re: New to CGAL
  • Date: Sat, 31 Mar 2012 13:58:36 +0200
Ampelion
writes:
> Hi,
> I'm learning c++ in order to use CGAL, and I'm having trouble compiling one
> of the examples. The error messages are below. What am I doing wrong? It is
> probably something silly.
I can't reproduce your error on CGAL 4.0. What CGAL version are you
using exactly? What is the output of gcc --version?
It seems you are not using CMake. Can you try `cgal_create_cmake_script`
in the alpha_shapes_3 example folder and use make to compile? e.g.:
cd /path/to/alpha_shapes_3/example
cmake .
make ex_alpha_shapes_with_fast_location_3
> The package is up-to-date as of December, and I've been using CGAL python
> bindings for a couple years with no problems (except that one of the
> functions I need was not ported).
There is a new CGAL bindings project [1] as CGAL python is no longer
maintained. Maybe what you need is there. Otherwise post a request on
the mailing list.
[snipped error]
Philipp Moeller
GeometryFactory
[1] : http://code.google.com/p/cgal-bindings/
