- To:
- Subject: Re: [cgal-discuss] Having Trouble Compiling AABB_triangle_3_example.cpp?
- Date: Tue, 03 Apr 2012 23:31:51 +0200
Le mardi 03 avril 2012 14:12:41 achen a écrit :
> Hi everybody,
> I'm running into a particularly frustrating bug. I'm working on an Ubuntu
> box and apt-get install'd the cgal-dev package.
> Upon attempting to g++ AABB_triangle_3_example.cpp -lCGAL I run into the
> http://pastebin.com/dMMnFmNP following error . I'm still pretty new to C++
> (I'm a Java/Python guy) so these compiling issues are really baffling me.
> I've spent a couple hours but google-fu is of no help so far.
> Is it the build of CGAL I obtained via apt-get the issue?
Can you tell us which version of CGAL you have on your Ubuntu? Or at least
the
version of Ubuntu you use?
Do you try to compile the example *unmodified*?
Laurent Rineau, PhD
- [cgal-discuss] Having Trouble Compiling AABB_triangle_3_example.cpp?, achen, 04/03/2012
- Re: [cgal-discuss] Having Trouble Compiling AABB_triangle_3_example.cpp?, Laurent Rineau (GeometryFactory), 04/03/2012
- [cgal-discuss] Re: Having Trouble Compiling AABB_triangle_3_example.cpp?, achen, 04/03/2012
- Re: [cgal-discuss] Re: Having Trouble Compiling AABB_triangle_3_example.cpp?, Laurent Rineau (GeometryFactory), 04/03/2012
- [cgal-discuss] Re: Having Trouble Compiling AABB_triangle_3_example.cpp?, achen, 04/06/2012
- Re: [cgal-discuss] Re: Having Trouble Compiling AABB_triangle_3_example.cpp?, Laurent Rineau (GeometryFactory), 04/06/2012
