cgal-discuss - [cgal-discuss] Re: Determine if a set of Point_3 is linear
  • To:
  • Subject: [cgal-discuss] Re: Determine if a set of Point_3 is linear
  • Date: Wed, 4 Apr 2012 19:41:02 -0700 (PDT)
You can use linear_least_squares_fitting_3 (
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Principal_component_analysis_ref/Function_linear_least_squares_fitting_3.html#Cross_link_anchor_1811
linear_least_squares_fitting documentation ) as returned value of this
function respsents fitting quality of given point set.
Another way, in my opinion, you can estimate line utilizing
linear_least_squares_fitting_3, and then calculating squared distance
between each point and the estiamted line, and obtaining sigma of this
estmation. A lower sigma means best fitting, i.e, this set of point is
likely to be linear.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Determine-if-a-set-of-Point-3-is-linear-tp4533408p4533830.html
