- To:
- Subject: Re: [cgal-discuss] CGAL "intersection" bug - URGENT
- Date: Fri, 06 Apr 2012 09:50:14 +0200
Hello,
Please stop posting messages with URGENT in the title, it has no
influence on the treatment. Moreover, I don't want that we end up
having URGENT in the title of each message of the list :)
For your problem, you cannot rely on a kernel with inexact
constructions to make a bug report. Here is what you should have used:
typedef CGAL::Exact_predicates_exact_constructions_kernel EKernel;
CGAL::Cartesian_converter<Kernel,EKernel> convert;
CGAL::Object object = CGAL::intersection(convert(segment_query), convert(triangle));
CGAL_assertion(object.empty());
For more details, please read:
http://www.cgal.org/FAQ.html#inexact_NT
But the bug was really here (because your points are aligned even with
floating point coordinates).
I joint the patch as well as the patched file
CGAL/internal/Intersections_3/Triangle_3_Segment_3_intersection.h
Thanks for the bug report,
Sebastien.
PS-SPAM: If you have URGENT questions that cannot wait the usual
answering delay of the list, note that GeometryFactory is selling
support licenses for a reasonable price. You can contact
to know more about these.
On 04/05/2012 11:44 PM, gupta61 wrote:
Hi,
I am reporting a problem with the "Segment-Triangle" intersection. If you
look at the code below I am trying to find a intersection between a Segment
and a Triangle. The answer should be that they do not intersect. When I use
"do_intersect" to find if they intersect, it gives me the correct result.
However when I ask "intersection" to tell me if it has an intersection, then
it gives me a segment as the intersection which is obviously wrong. Let me
know if I am missing something. I am mentioning the various things I have
tried.
I have tried with this problem with three versions of CGAL (3.8, 3.9,
4.0-beta1).
I also tried these kernels:
#include<CGAL/Exact_predicates_exact_constructions_kernel.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
#include<CGAL/Simple_cartesian.h>
typedef CGAL::Simple_cartesian<double> Kernel;
and got the same wrong results...
I am also mentioning the code which we used for this.
#include<cstdlib>
#include<string>
#include<cstdio>
#include<CGAL/Exact_predicates_inexact_constructions_kernel.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
//#include<CGAL/Exact_predicates_exact_constructions_kernel.h>
//typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
//#include<CGAL/Simple_cartesian.h>
//typedef CGAL::Simple_cartesian<double> Kernel;
#include<CGAL/intersections.h>
#include<CGAL/Bbox_3.h>
typedef CGAL::Point_3<Kernel> CGALPoint3;
typedef CGAL::Segment_3<Kernel> CGALSegment3;
typedef CGAL::Triangle_3<Kernel> CGALTriangle3;
int main(int argc, char** argv) {
CGALSegment3 segment_query( CGALPoint3(0.125, 0, -0.125),
CGALPoint3(0.25, 0, -0.125) );
CGALTriangle3 triangle( CGALPoint3(0.2500001, 0, -0.125) /* vertex
6*/,
CGALPoint3(1.0278171, 0, -0.125) /* vertex 10*/,
CGALPoint3(1.0278171, 0, -0.250001) /* vertex 9*/ );
std::cout<< std::setw(12)<< std::setprecision( 15 )
<< "\nSegment query: "<< segment_query<< std::endl;
<< "\nTriangle: "<< triangle<< std::endl;
bool do_intersect = CGAL::do_intersect(segment_query, triangle);
std::cout<< "\nCGAL::do_intersect (0/1) = "<< do_intersect<< std::endl;
// Compute actual intersection(s)
CGAL::Object object = CGAL::intersection(segment_query, triangle);
// check if it is a point
const CGALPoint3* p_point=0;
const CGALSegment3* p_segm=0;
if( (p_point = CGAL::object_cast<CGALPoint3>(&object)) ) {
std::cout<< "\nEncountered intersection object is a point"<<
std::endl;
std::cout<< std::setw(12)<< std::setprecision( 15 )<< (*p_point)<<
std::endl;
else if ( (p_segm = CGAL::object_cast<CGALSegment3>(&object)) ) {
// Check if it is a segment otherwise error out
std::cout<< "\nEncountered intersection object is a segment"<<
std::endl;
std::cout<< std::setw(12)<< std::setprecision( 15 )<< (*p_segm)<<
std::endl;
else {
std::cerr<< "\nInvalid object returned by aaa_bb tree"<< std::endl;
return 0;
We got the following result which is obviously wrong as explained before.
Segment query: 0.125 0 -0.125 0.25 0 -0.125
Triangle: 0.2500001 0 -0.125 1.0278171 0 -0.125 1.0278171 0 -0.250001
CGAL::do_intersect (0/1) = 0
Can you explain why I am getting this result or if you can confirm if it is
a bug ?
Thanks,
Piyush Gupta
UIUC
Piyush Gupta
UIUC
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-intersection-bug-URGENT-tp4536168p4536168.html
branches/next/Intersections_3/include/CGAL/internal/Intersections_3/Triangle_3_Segment_3_intersection.h
2012-04-05 10:56:28 UTC (rev 68386)
2012-04-05 11:57:58 UTC (rev 68387)
@@ -156,26 +156,36 @@
typename K::Equal_3 equals = k.equal_3_object();
- // possible orders: [p,a,b,q], [p,a,q,b], [a,p,b,q], [a,p,q,b]
- if ( collinear_ordered(p,a,q) )
+ // possible orders: [p,a,b,q], [p,a,q,b], [p,q,a,b], [a,p,b,q], [a,p,q,b],
[a,b,p,q]
+ if ( collinear_ordered(p,a,b) )
// p is before a
- if ( collinear_ordered(p,b,q) )
- return make_object(segment(a,b));
- else
- return equals(a,q)?
- make_object(a):
- make_object(segment(a,q));
+ //possible orders: [p,a,b,q], [p,a,q,b], [p,q,a,b]
+ if ( collinear_ordered(a,b,q) )
+ return make_object(segment(a,b)); //[p,a,b,q]
+ else{
+ if ( collinear_ordered(q,a,b) )
+ return equals(a,q)? //[p,q,a,b]
+ make_object(a):
+ Object();
+ return make_object(segment(a,q)); //[p,a,q,b]
else
// p is after a
+ //possible orders: [a,p,b,q], [a,p,q,b], [a,b,p,q]
- return equals(p,b)?
+ return equals(p,b)? // [a,p,b,q]
make_object(p):
make_object(segment(p,b));
- else
- return make_object(segment(p,q));
+ else{
+ if ( collinear_ordered(a,b,p) )
+ return equals(p,b)? // [a,b,p,q]
+ make_object(p):
+ Object();
+ return make_object(segment(p,q)); // [a,p,q,b]
// Copyright (c) 2009 GeometryFactory (France), INRIA Sophia-Antipolis (France). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you can redistribute it and/or // modify it under the terms of the GNU Lesser General Public License as // published by the Free Software Foundation; either version 3 of the License, // or (at your option) any later version. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/next/Intersections_3/include/CGAL/internal/Intersections_3/Triangle_3_Segment_3_intersection.h $ // $Id: Triangle_3_Segment_3_intersection.h 67093 2012-01-13 11:22:39Z lrineau $ // // // Author(s) : Laurent Rineau, Stephane Tayeb // // Note: This implementation is adapted from Triangle_3_Segment_3_do_intersect.h #ifndef CGAL_INTERNAL_INTERSECTIONS_3_TRIANGLE_3_SEGMENT_3_INTERSECTION_H #define CGAL_INTERNAL_INTERSECTIONS_3_TRIANGLE_3_SEGMENT_3_INTERSECTION_H #include <CGAL/kernel_basic.h> #include <CGAL/intersections.h> namespace CGAL { namespace internal { template <class K> typename K::Point_3 t3s3_intersection_coplanar_aux(const typename K::Point_3& p, const typename K::Point_3& q, const typename K::Point_3& a, const typename K::Point_3& b, const K& k) { // Returns the intersection point between segment [p,q] and [a,b] // // preconditions: // + p,q,a,b are coplanar typedef typename K::Point_3 Point_3; typedef typename K::Vector_3 Vector_3; typedef typename K::FT FT; typename K::Construct_vector_3 vector = k.construct_vector_3_object(); typename K::Construct_cross_product_vector_3 cross_product = k.construct_cross_product_vector_3_object(); typename K::Compute_scalar_product_3 scalar_product = k.compute_scalar_product_3_object(); typename K::Compute_squared_length_3 sq_length = k.compute_squared_length_3_object(); const Vector_3 pq = vector(p,q); const Vector_3 ab = vector(a,b); const Vector_3 pa = vector(p,a); const Vector_3 pa_ab = cross_product(pa,ab); const Vector_3 pq_ab = cross_product(pq,ab); const FT t = scalar_product(pa_ab,pq_ab) / sq_length(pq_ab); return ( p + t*pq ); } template <class K> Object t3s3_intersection_coplanar_aux(const typename K::Point_3& a, const typename K::Point_3& b, const typename K::Point_3& c, const typename K::Point_3& p, const typename K::Point_3& q, const bool negative_side, const K& k) { // This function is designed to clip pq into the triangle abc. // Point configuration should be as follows // // +p // | +b // | // +c | +a // | // +q // // We know that c is isolated on the negative side of pq, but we don't know // p position wrt [bc]&[ca] and q position wrt [bc]&[ca] typedef typename K::Point_3 Point_3; typename K::Coplanar_orientation_3 coplanar_orientation = k.coplanar_orientation_3_object(); typename K::Construct_segment_3 segment = k.construct_segment_3_object(); const Orientation bcq = coplanar_orientation(b,c,q); const Orientation cap = coplanar_orientation(c,a,p); if ( NEGATIVE == bcq || NEGATIVE == cap ) return Object(); else if ( COLLINEAR == bcq ) // q is inside [c,b], p is outside t (because of pqc) return make_object(q); else if ( COLLINEAR == cap ) // p is inside [c,a], q is outside t (because of pqc) return make_object(p); else // bcq == POSITIVE && cap == POSITIVE { // Here we know the intersection is not empty // Let's get the intersection points Point_3 p_side_end_point(p); if ( NEGATIVE == coplanar_orientation(b,c,p) ) { p_side_end_point = t3s3_intersection_coplanar_aux(p,q,b,c,k); } Point_3 q_side_end_point(q); if ( NEGATIVE == coplanar_orientation(c,a,q) ) { q_side_end_point = t3s3_intersection_coplanar_aux(p,q,c,a,k); } if ( negative_side ) return make_object(segment(p_side_end_point, q_side_end_point)); else return make_object(segment(q_side_end_point, p_side_end_point)); } } template <class K> Object t3s3_intersection_collinear_aux(const typename K::Point_3& a, const typename K::Point_3& b, const typename K::Point_3& p, const typename K::Point_3& q, const K& k) { // Builds resulting segment of intersection of [a,b] and [p,q] // Precondition: [a,b] and [p,q] have the same direction typename K::Construct_segment_3 segment = k.construct_segment_3_object(); typename K::Collinear_are_ordered_along_line_3 collinear_ordered = k.collinear_are_ordered_along_line_3_object(); typename K::Equal_3 equals = k.equal_3_object(); // possible orders: [p,a,b,q], [p,a,q,b], [p,q,a,b], [a,p,b,q], [a,p,q,b], [a,b,p,q] if ( collinear_ordered(p,a,b) ) { // p is before a //possible orders: [p,a,b,q], [p,a,q,b], [p,q,a,b] if ( collinear_ordered(a,b,q) ) return make_object(segment(a,b)); //[p,a,b,q] else{ if ( collinear_ordered(q,a,b) ) return equals(a,q)? //[p,q,a,b] make_object(a): Object(); return make_object(segment(a,q)); //[p,a,q,b] } } else { // p is after a //possible orders: [a,p,b,q], [a,p,q,b], [a,b,p,q] if ( collinear_ordered(p,b,q) ) return equals(p,b)? // [a,p,b,q] make_object(p): make_object(segment(p,b)); else{ if ( collinear_ordered(a,b,p) ) return equals(p,b)? // [a,b,p,q] make_object(p): Object(); return make_object(segment(p,q)); // [a,p,q,b] } } } template <class K> Object intersection_coplanar(const typename K::Triangle_3 &t, const typename K::Segment_3 &s, const K & k ) { CGAL_kernel_precondition( ! k.is_degenerate_3_object()(t) ) ; CGAL_kernel_precondition( ! k.is_degenerate_3_object()(s) ) ; typedef typename K::Point_3 Point_3; typename K::Construct_point_on_3 point_on = k.construct_point_on_3_object(); typename K::Construct_vertex_3 vertex_on = k.construct_vertex_3_object(); typename K::Coplanar_orientation_3 coplanar_orientation = k.coplanar_orientation_3_object(); typename K::Collinear_are_ordered_along_line_3 collinear_ordered = k.collinear_are_ordered_along_line_3_object(); const Point_3 & p = point_on(s,0); const Point_3 & q = point_on(s,1); const Point_3 & A = vertex_on(t,0); const Point_3 & B = vertex_on(t,1); const Point_3 & C = vertex_on(t,2); int k0 = 0; int k1 = 1; int k2 = 2; // Determine the orientation of the triangle in the common plane if (coplanar_orientation(A,B,C) != POSITIVE) { // The triangle is not counterclockwise oriented // swap two vertices. std::swap(k1,k2); } const Point_3& a = vertex_on(t,k0); const Point_3& b = vertex_on(t,k1); const Point_3& c = vertex_on(t,k2); // Test whether the segment's supporting line intersects the // triangle in the common plane const Orientation pqa = coplanar_orientation(p,q,a); const Orientation pqb = coplanar_orientation(p,q,b); const Orientation pqc = coplanar_orientation(p,q,c); switch ( pqa ) { // ----------------------------------- // pqa POSITIVE // ----------------------------------- case POSITIVE: switch ( pqb ) { case POSITIVE: switch ( pqc ) { case POSITIVE: // the triangle lies in the positive halfspace // defined by the segment's supporting line. return Object(); case NEGATIVE: // c is isolated on the negative side return t3s3_intersection_coplanar_aux(a,b,c,p,q,true,k); case COLLINEAR: if ( collinear_ordered(p,c,q) ) // c is inside [p,q] return make_object(c); else return Object(); } case NEGATIVE: if ( POSITIVE == pqc ) // b is isolated on the negative side return t3s3_intersection_coplanar_aux(c,a,b,p,q,true,k); else // a is isolated on the positive side return t3s3_intersection_coplanar_aux(b,c,a,q,p,false,k); case COLLINEAR: switch ( pqc ) { case POSITIVE: if ( collinear_ordered(p,b,q) ) // b is inside [p,q] return make_object(b); else return Object(); case NEGATIVE: // a is isolated on the positive side return t3s3_intersection_coplanar_aux(b,c,a,q,p,false,k); case COLLINEAR: // b,c,p,q are aligned, [p,q]&[b,c] have the same direction return t3s3_intersection_collinear_aux(b,c,p,q,k); } default: // should not happen. CGAL_error(); return Object(); } // ----------------------------------- // pqa NEGATIVE // ----------------------------------- case NEGATIVE: switch ( pqb ) { case POSITIVE: if ( POSITIVE == pqc ) // a is isolated on the negative side return t3s3_intersection_coplanar_aux(b,c,a,p,q,true,k); else // b is isolated on the positive side return t3s3_intersection_coplanar_aux(c,a,b,q,p,false,k); case NEGATIVE: switch ( pqc ) { case POSITIVE: // c is isolated on the positive side return t3s3_intersection_coplanar_aux(a,b,c,q,p,false,k); case NEGATIVE: // the triangle lies in the negative halfspace // defined by the segment's supporting line. return Object(); case COLLINEAR: if ( collinear_ordered(p,c,q) ) // c is inside [p,q] return make_object(c); else return Object(); } case COLLINEAR: switch ( pqc ) { case POSITIVE: // a is isolated on the negative side return t3s3_intersection_coplanar_aux(b,c,a,p,q,true,k); case NEGATIVE: if ( collinear_ordered(p,b,q) ) // b is inside [p,q] return make_object(b); else return Object(); case COLLINEAR: // b,c,p,q are aligned, [p,q]&[c,b] have the same direction return t3s3_intersection_collinear_aux(c,b,p,q,k); } default: // should not happen. CGAL_error(); return Object(); } // ----------------------------------- // pqa COLLINEAR // ----------------------------------- case COLLINEAR: switch ( pqb ) { case POSITIVE: switch ( pqc ) { case POSITIVE: if ( collinear_ordered(p,a,q) ) // a is inside [p,q] return make_object(a); else return Object(); case NEGATIVE: // b is isolated on the positive side return t3s3_intersection_coplanar_aux(c,a,b,q,p,false,k); case COLLINEAR: // a,c,p,q are aligned, [p,q]&[c,a] have the same direction return t3s3_intersection_collinear_aux(c,a,p,q,k); } case NEGATIVE: switch ( pqc ) { case POSITIVE: // b is isolated on the negative side return t3s3_intersection_coplanar_aux(c,a,b,p,q,true,k); case NEGATIVE: if ( collinear_ordered(p,a,q) ) // a is inside [p,q] return make_object(a); else return Object(); case COLLINEAR: // a,c,p,q are aligned, [p,q]&[a,c] have the same direction return t3s3_intersection_collinear_aux(a,c,p,q,k); } case COLLINEAR: switch ( pqc ) { case POSITIVE: // a,b,p,q are aligned, [p,q]&[a,b] have the same direction return t3s3_intersection_collinear_aux(a,b,p,q,k); case NEGATIVE: // a,b,p,q are aligned, [p,q]&[b,a] have the same direction return t3s3_intersection_collinear_aux(b,a,p,q,k); case COLLINEAR: // case pqc == COLLINEAR is impossible since the triangle is // assumed to be non flat CGAL_error(); return Object(); } default: // should not happen. CGAL_error(); return Object(); } default:// should not happen. CGAL_error(); return Object(); } } template <class K> Object intersection(const typename K::Triangle_3 &t, const typename K::Segment_3 &s, const K & k) { CGAL_kernel_precondition( ! k.is_degenerate_3_object()(t) ) ; CGAL_kernel_precondition( ! k.is_degenerate_3_object()(s) ) ; typedef typename K::Point_3 Point_3; typename K::Construct_point_on_3 point_on = k.construct_point_on_3_object(); typename K::Construct_vertex_3 vertex_on = k.construct_vertex_3_object(); typename K::Orientation_3 orientation = k.orientation_3_object(); typename K::Intersect_3 intersection = k.intersect_3_object(); const Point_3 & a = vertex_on(t,0); const Point_3 & b = vertex_on(t,1); const Point_3 & c = vertex_on(t,2); const Point_3 & p = point_on(s,0); const Point_3 & q = point_on(s,1); const Orientation abcp = orientation(a,b,c,p); const Orientation abcq = orientation(a,b,c,q); switch ( abcp ) { case POSITIVE: switch ( abcq ) { case POSITIVE: // the segment lies in the positive open halfspaces defined by the // triangle's supporting plane return Object(); case NEGATIVE: // p sees the triangle in counterclockwise order if ( orientation(p,q,a,b) != POSITIVE && orientation(p,q,b,c) != POSITIVE && orientation(p,q,c,a) != POSITIVE ) { // The intersection should be a point Object obj = intersection(s.supporting_line(),t.supporting_plane()); if ( obj.is<typename K::Line_3>() ) return Object(); else return obj; } else return Object(); case COPLANAR: // q belongs to the triangle's supporting plane // p sees the triangle in counterclockwise order if ( orientation(p,q,a,b) != POSITIVE && orientation(p,q,b,c) != POSITIVE && orientation(p,q,c,a) != POSITIVE ) return make_object(q); else return Object(); default: // should not happen. CGAL_error(); return Object(); } case NEGATIVE: switch ( abcq ) { case POSITIVE: // q sees the triangle in counterclockwise order if ( orientation(q,p,a,b) != POSITIVE && orientation(q,p,b,c) != POSITIVE && orientation(q,p,c,a) != POSITIVE ) { Object obj = intersection(s.supporting_line(),t.supporting_plane()); if ( obj.is<typename K::Line_3>() ) return Object(); else return obj; } else return Object(); case NEGATIVE: // the segment lies in the negative open halfspaces defined by the // triangle's supporting plane return Object(); case COPLANAR: // q belongs to the triangle's supporting plane // p sees the triangle in clockwise order if ( orientation(q,p,a,b) != POSITIVE && orientation(q,p,b,c) != POSITIVE && orientation(q,p,c,a) != POSITIVE ) return make_object(q); else return Object(); default: // should not happen. CGAL_error(); return Object(); } case COPLANAR: // p belongs to the triangle's supporting plane switch ( abcq ) { case POSITIVE: // q sees the triangle in counterclockwise order if ( orientation(q,p,a,b) != POSITIVE && orientation(q,p,b,c) != POSITIVE && orientation(q,p,c,a) != POSITIVE ) return make_object(p); else return Object(); case NEGATIVE: // q sees the triangle in clockwise order if ( orientation(p,q,a,b) != POSITIVE && orientation(p,q,b,c) != POSITIVE && orientation(p,q,c,a) != POSITIVE ) return make_object(p); else return Object(); case COPLANAR: // the segment is coplanar with the triangle's supporting plane // we test whether the segment intersects the triangle in the common // supporting plane return intersection_coplanar(t,s,k); default: // should not happen. CGAL_error(); return Object(); } default: // should not happen. CGAL_error(); return Object(); } } template <class K> inline Object intersection(const typename K::Segment_3 &s, const typename K::Triangle_3 &t, const K & k) { return internal::intersection(t,s,k); } } // end namespace internal template <class K> inline Object intersection(const Triangle_3<K> &t, const Segment_3<K> &s) { return typename K::Intersect_3()(t, s); } template <class K> inline Object intersection(const Segment_3<K> &s, const Triangle_3<K> &t) { return typename K::Intersect_3()(t, s); } } // end namespace CGAL #endif // CGAL_INTERNAL_INTERSECTIONS_3_TRIANGLE_3_SEGMENT_3_INTERSECTION_H
- [cgal-discuss] CGAL "intersection" bug - URGENT, gupta61, 04/05/2012
- Re: [cgal-discuss] CGAL "intersection" bug - URGENT, Sebastien Loriot (GeometryFactory), 04/06/2012
- [cgal-discuss] Re: CGAL "intersection" bug - URGENT, gupta61, 04/06/2012
