- To:
- Subject: Re: [cgal-discuss] Voronoi diagram vertices
- Date: Mon, 9 Apr 2012 12:06:25 +0200
In the traits class there is a functor: Construct_svd_vertex_2. This gives you the Voronoi vertex.
Does it mean that coordinates of the Voronoi vertices are not computed during segment Delaunay graph construction (only topology is built)?
However, in order to work correctly you need to use a number type that supports field operations and square roots.
Let's say I provided proper number types that support field operations and square roots, what is the precision I should expect for coordinates of the Voronoi vertices in case they are doubles (64 bit floating-point type)?
Regards,
Andrii
- [cgal-discuss] Voronoi diagram vertices, sydorchuk.andriy, 04/09/2012
- Re: [cgal-discuss] Voronoi diagram vertices, Menelaos Karavelas, 04/09/2012
- Re: [cgal-discuss] Voronoi diagram vertices, Andrii Sydorchuk, 04/09/2012
