cgal-discuss - [cgal-discuss] Create Polyhedron from given Planes
  • To:
  • Subject: [cgal-discuss] Create Polyhedron from given Planes
  • Date: Wed, 18 Apr 2012 08:34:36 -0700 (PDT)
Hello to all users,
I would like to ask how can I create a polyhedron if I have a set of planes?
Or with other words how can I transform a polyhedron from plane
representation to vertices or to facets representation?
for example I can do the opposite with the following
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Polyhedron_3<K>
Polyhedron_3;
//a functor computing the plane containing a triangular facet
struct Plane_from_facet {
Polyhedron_3::Plane_3 operator()(Polyhedron_3::Facet& f) {
Polyhedron_3::Halfedge_handle h = f.halfedge();
return Polyhedron_3::Plane_3( h->vertex()->point(),
h->next()->vertex()->point(),
h->opposite()->vertex()->point());
int _tmain(int argc, _TCHAR* argv[])
Polyhedron_3 poly;
// Add vertices end edges to Polyhedron, so I have its facets
std::transform( poly.facets_begin(), poly.facets_end(),
poly.planes_begin(),Plane_from_facet());
So, my question is that if I have a set of planes, how I take the polyhedron
that they create when they intersect?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Create-Polyhedron-from-given-Planes-tp4568074p4568074.html
