cgal-discuss - Re: Re: [cgal-discuss] pb with ofstream ?
  • To:
  • Subject: Re: Re: [cgal-discuss] pb with ofstream ?
  • Date: Wed, 25 Apr 2012 18:07:17 +0200
Le mercredi 25 avril 2012 17:54:23
a écrit :
> i understand nothing: i wanted to compile in multi-thread-debug (MTd) but i
> was said that i had to compile in dynamic mode . Isn't it ? which mode do
> you want me to compile with ?
My bad, /MD or /MDd is the right one.
Have you compile the example using a MSVC project that is generated by CMake?
What is strange is that the CGAL project has a testsuite with builders that
use /MD and /MDd (with VC9 or VC10). I do not understand why it does not work
for you.
All the symptoms you have seem to tell that you are mixing static and dynamic
runtimes, in a way. I do not know what you may have done to have those errors.
Laurent Rineau, PhD
