cgal-discuss - Re: [cgal-discuss] Re: CGAL+GMP and multithreading crash
  • To: Marc Glisse <>
  • Cc:
  • Subject: Re: [cgal-discuss] Re: CGAL+GMP and multithreading crash
  • Date: Wed, 2 May 2012 09:33:23 +0200
Thanks for your answer. I am also considering the alternative of making copies of all the objects that may be accessed by several threads.. However, since all copies of an object share a common representation object storing the data associated with a kernel object how this solution could be thread safe with the current implementation?
Best Regards,
Ioannis
2012/5/1 Marc Glisse <>
On Tue, 1 May 2012, Philipp Moeller wrote:
Another approach I have been pondering is to simply throw all our ref
counted objects into shared_ptr.
That is a possibility, but the interface is far from a perfect match, especially if you take all the variants we have in cgal into account.
At least the boost version uses atomic counters on most platforms
The standard libraries that come with gcc, llvm and visual studio all do.
This might have some drawbacks I don't see yet. At least
boost::shared_ptr is known to have some performance deficiencies
compared to vendor implementations.
shared_ptr has heavier functionalities than a simple reference-counted structure which makes it unavoidably slower. The boost library might be particularly bad, I don't know, but the last time I looked (possibly 2009), if I remember correctly, it was orders of magnitude slower than anything else I tried, for this use. Or maybe that was gcc's placeholder atomic implementation (they have a real one now)? Well, boost certainly wasn't among the faster alternatives.
It is certainly worth reevaluating today, if someone has time...
Marc Glisse
