cgal-discuss - Re: [cgal-discuss] Re: Error configuring CMake to work with VS2008 WIN64
  • To:
  • Subject: Re: [cgal-discuss] Re: Error configuring CMake to work with VS2008 WIN64
  • Date: Wed, 2 May 2012 13:19:36 +0200
This was eventually a problem with visual studio, not with cmake or
CGAL. I had to add %systemroot% to the VC++ directories, because the
existence of several versions of VS on the same computer made a mess.
Amir.
On Tue, May 1, 2012 at 10:14 AM, Zohar
wrote:
> AMD64 is a synonym for x64.
> Did you notice that the cl.exe is run from ver 10.0?
> Check your environment vars, such as VS90COMNTOOLS, and that no bin
> directory is in the path.
> Also I heard a rumor that cmake might have problems with non-legit versions.
> View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/Error-configuring-CMake-to-work-with-VS2008-WIN64-tp4598203p4600320.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
