- To:
- Subject: Re: [cgal-discuss] Re: Problems updating Poin_d's memebers
- Date: Fri, 04 May 2012 00:10:32 +0200
Marc Glisse
writes:
> On Thu, 3 May 2012, Philipp Moeller wrote:
>> I can confirm the same on a recent gcc. Looks like a bug in
>> Lazy_exact_nt to me. Point_d::operator[] returns by value as documented
>> but assignment does work for some unknown reason.
> Why wouldn't it?
> struct A {};
> A f(){return A();}
> void g(){ f()=A(); }
> operator= is a member function like any other.
I erroneously believed that you could only call const-member functions
on a temporary as you can only bind it to a reference-to-const. This
seems a little useless pre-C++11, but makes some sense if you have move
semantics.
Thanks for pointing it out.
> The operation is forbidden for builtin types, or if f returns const A
> (used to be a popular technique), or in C++11 if operator= has a '&'
> at the end of its declaration.
>> If operator[] should really return by value is another issue. It is
>> certainly necessary for a Homogeneous kernel, but not a Cartesian. Seems
>> wasteful in case of a ref counted NT representation.
> An important point of ref-counting in CGAL is not to care about
> this. It is for non-ref counted types that it is wasteful.
This still will make the ref-count increment and decrement
unnecessarily. Even if we had atomic counters we should try to avoid
that.
Philipp Moeller
GeometryFactory
- [cgal-discuss] Problems updating Poin_d's memebers, luchia, 05/03/2012
- Re: [cgal-discuss] Problems updating Poin_d's memebers, Philipp Moeller, 05/03/2012
- [cgal-discuss] Re: Problems updating Poin_d's memebers, luchia, 05/03/2012
- Re: [cgal-discuss] Re: Problems updating Poin_d's memebers, Philipp Moeller, 05/03/2012
- Re: [cgal-discuss] Re: Problems updating Poin_d's memebers, Marc Glisse, 05/03/2012
- Re: [cgal-discuss] Re: Problems updating Poin_d's memebers, Philipp Moeller, 05/04/2012
