- To:
- Subject: Re: [cgal-discuss] Generation of a 3d mesh from segmented image
- Date: Tue, 15 May 2012 15:03:50 -0700
Dear Laurent, thanks for your help.
I think I can figure out a way to get that information from the
segmented image ... how do I need to encode that information?
Andrea
On Tue, May 15, 2012 at 8:17 AM, Laurent Rineau (GeometryFactory)
wrote:
> Le lundi 14 mai 2012 11:29:01 Andrea Cortis a écrit :
>> Dear All,
>> I am new to CGAL and seeking help on how to generate a 3d mesh from a
>> segmented image.
>> So far I have been able to run the examples at
>> [1]
>> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_3/Chapter_main.
>> html#Subsection_50.3.3
>> [2]
>> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesher/Chapt
>> er_main.html
>> I have also run some examples on my own images, but I am finding some
>> problems with segmented images that consist of isolated regions. In
>> particular, I have noticed that, generally speaking (1) only some of
>> the isolated regions are correctly spotted, and (2) which regions are
>> spotted depends on the center and radius of the ball in link [2] and,
>> for the same radius and center, it depends on the particular
>> random_seed number.
>> I have uploaded a "test.inr" file at this location:
>> http://www.tempfiles.net/download/201205/243508/test.html
>> (Please let me know if you are able to download it correctly)
>> I would greatly appreciate any help on this problem. Thanks in advance,
> Do you have a way to know in advance how many isolated regions you have, do
> you have a way to find an rough enclosing sphere for each (with the
> constraint
> that the center of the sphere is inside the region)? In that case I might
> help.
> The issue is the initialization step of the meshing process. It uses random
> ray queries, issuing from the center of the sphere you give. To find out all
> regions, one needs to run that process for each region.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Generation of a 3d mesh from segmented image, Andrea Cortis, 05/14/2012
- Re: [cgal-discuss] Generation of a 3d mesh from segmented image, Laurent Rineau (GeometryFactory), 05/15/2012
- Re: [cgal-discuss] Generation of a 3d mesh from segmented image, Andrea Cortis, 05/16/2012
