cgal-discuss - Re: [cgal-discuss] KNN or ball-search in AABB tree
  • To:
  • Subject: Re: [cgal-discuss] KNN or ball-search in AABB tree
  • Date: Fri, 18 May 2012 10:55:45 +0200
If you look at the implementation of the function in AABB_tree.h,
you'll see that this operation is done thanks to a traversal traits
"Projection_traits".
If you look at the implementation of this traits in the file internal/AABB_tree/AABB_traversal_traits.h you can create
a new traversal traits class that can do what you want.
Sebastien.
On 05/16/2012 11:31 AM, libicocco wrote:
Hello,
I'm a newbie in CGAL. I'm wondering if it's possible to obtain a number of
nearest points and primitives (instead of one as in
closest_point_and_primitive). Since, according to the documentation, the
closest point is found by a ball search, I assumed it would be easy to
convert this function into a k-nearest neighbor or to a radius search. The
purpose is to reject the closest points with a normal which is incoherent to
the query normal.
Has anybody done that? What is the simplest/fastest way of doing it?
Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/KNN-or-ball-search-in-AABB-tree-tp4641090.html
