cgal-discuss - [cgal-discuss] Re: Getting the trapezoid cells from Arr_trapezoid_ric_point_location
  • To:
  • Subject: [cgal-discuss] Re: Getting the trapezoid cells from Arr_trapezoid_ric_point_location
  • Date: Sun, 20 May 2012 01:08:49 -0700 (PDT)
I used the function CGAL::decompose. I
http://cgal-discuss.949826.n4.nabble.com/file/n4646703/untitled.png The
image I've attached is what I'm trying to decompose: the vertices of a
triangle bounded by a rectangle. The 3 different plots shows, for each of
the triangle vertices, the edge above (in red), and the edge below (in
green). I have absolutely no idea how such output can be used for
trapezoidal decomposition.
Attached is the actual code I use.
http://cgal-discuss.949826.n4.nabble.com/file/n4646703/testDecomposition.cpp
(I use the testB function).
Please help me making sense out of the decompose output.
Julien Esposito
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Getting-the-trapezoid-cells-from-Arr-trapezoid-ric-point-location-tp4443028p4646703.html
