Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
- To:
- Subject: Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
- Date: Sun, 20 May 2012 12:39:56 +0300
It is already added to the system variables. Can u plz tell me how do I copy the DLLs to the directory of the application? I didn't get what u mean exactly!
Thanks
On 20 May 2012 12:11, Laurent Rineau (GeometryFactory) <> wrote:
Le dimanche 20 mai 2012 10:52:44 Sweety Pie a écrit :
> Thanks for the reply. It is already added to theYou need to add the path C:\CGAL-3.9\auxiliary\gmp\lib in the PATH environment
> additional dependencies and the VC++ directories as well. Am still getting
> the same issue :(
> Any other suggestions??
version. Or copy the DLLs in the directory of the applications you want to
run.
Laurent Rineau, PhD
- [cgal-discuss] The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Sweety Pie, 05/20/2012
- [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, flavio.anjos, 05/20/2012
- Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Sweety Pie, 05/20/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Laurent Rineau (GeometryFactory), 05/20/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Sweety Pie, 05/20/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, , 05/20/2012
- Re: Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Laurent Rineau (GeometryFactory), 05/20/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, flavio.anjos, 05/20/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, flavio.anjos, 05/21/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Sweety Pie, 05/21/2012
