cgal-discuss - Re: [cgal-discuss] Re: looking for method to convert 2D triangulation into Delaunay
  • To:
  • Subject: Re: [cgal-discuss] Re: looking for method to convert 2D triangulation into Delaunay
  • Date: Fri, 25 May 2012 11:49:44 +0200
Hi again
These are some preliminary results.
by passing a whole vector of 100K random vertices inside a square region..
<begin_code>
constrained_del_tri.insert(vertices.begin(), vertices.end())
<end_code>
cgal was able to build the constrained delaunay triangulation in just 0.233020 secs
this with a 2.0 Ghz AMD laptop (not the best hardware).
Is there any reference from the literature (or manual) about this fact you mentioned (rebuilding vs improving a delaunay mesh)?
Improving you triangulation by flipping (while there is an edge which is not locally Delaunay: flip it)
may need a quadratic number of flips in the worst case (there is example that need this number of flip [Hurtado...])
while the construction from scratch use spatial sorting (O(n log n) and the compute the triangulation
in linear time in practice.
Thus the interest of flipping algo arise only if your starting triangulation is quite good.
My timing (code below):
Static Delaunay triangulation of 1000000 points in dim 2 done in 1.34564 micro-seconds per point.
checked in 0.666302 micro-seconds per point.
thus just checking the triangulation is half of constructing it.
Hard for flipping to be better than construction from scratch.
Olivier
---- code
#include <iostream>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/point_generators_2.h>
#include <CGAL/iterator.h>
#include <CGAL/Timer.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Delaunay_triangulation_2<K> DT;
typedef CGAL::Random_points_in_square_2<DT::Point> Rnd_points_it;
typedef CGAL::Counting_iterator<Rnd_points_it, DT::Point> Points_iterator;
int main (int argc, char **argv)
{ int N = 1000000; if( argc > 1 )N = atoi(argv[1]); // number of points
Rnd_points_it rand_it( 1.0);
Points_iterator begin(rand_it), end(rand_it,N);
DT dt;
CGAL::Timer cost; cost.reset();cost.start();
std::cout << " Static Delaunay triangulation of "<<N<<" points in dim 2"<< std::flush;
dt.insert(begin,end);cost.stop();
std::cout << " done in "<<cost.time()/N*1000000<<" micro-seconds per point." << std::endl;
dt.is_valid();
std::cout << " checked in "<<cost.time()/N*1000000<<" micro-seconds per point." << std::endl;
return 0;
