- To:
- Subject: Re: [cgal-discuss] Crash with Nef_Polyhedrons
- Date: Mon, 28 May 2012 08:38:51 +0200
On 05/07/2012 06:01 PM, antoine wrote:
Hello,
I'm a new CGAL user, and am especially interested in Nef_Polyhedrons_2 :
I'm actually using an Apollonius graph, and convert it into a nef polyhedron
(N1). This seems to be working fine.
Then, I need to generate another nef polyhedron (N2), based on a given
skeleton and its width. The generation of this one seems to be working fine
too.
Both of them are well imported inside CGAL's Nef_Polyhedron_2 demo.
However, when I try N1.join(N2) (or any other operation), the program
crashes ("xxx.exe stopped working" and windows trying to find a solution).
I have tried using different types :
1: typedef CGAL::Gmpz
CGAL_RT;
typedef CGAL::Filtered_extended_homogeneous<CGAL_RT>
CGAL_ExtendedKernel;
2: typedef CGAL::Filtered_extended_homogeneous<int>
3: typedef CGAL::Exact_predicates_inexact_constructions_kernel
CGAL_Kernel ;
typedef Extended_cartesian<CGAL_Kernel::FT>
The Kernel 1 should be fine.
The Kernel 2 is dangerous as you can get overflow.
The Kernel 3 is not correct, it has inexact constructions.
I tried opening the file provided and get assertion on reading.
Can you provide a minimal example program showing the problem?
(reading + union + crash)
Sebastien.
with :
typedef CGAL::Nef_polyhedron_2<CGAL_ExtendedKernel>
CGAL_Polyhedron;
The first one crashes as soon as I create a new
CGAL_Polyhedron(CGAL_Polyhedron::EMPTY).
The second and third ones crash during the join operation (based on what I
read here, it may be due to a precision issue).
I have no idea on why the program crashes with gmpz stuff, and would really
apreciate if someone could help me on that, or to make the other methods
work.
I've enclosed the resulting files too, so if there is something wrong with
them, please tell me (The first one is the result of the export of the
Apollonius graph, I.E. 7 regions. The other one is the result of the
skeleton "enlargement" : Basically, the contours of a set of roads). They
should both be openable (and usable) with the Nef_Polyhedron_2 demo
(http://www.cgal.org/demo/4.0/nef_2.zip).
Thanks in advance,
Antoine.
http://cgal-discuss.949826.n4.nabble.com/file/n4615185/ApoloniusPolyhedron.cgal
http://cgal-discuss.949826.n4.nabble.com/file/n4615185/SkeletonPolyhedron.cgal
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Crash-with-Nef-Polyhedrons-tp4615185.html
- [cgal-discuss] Crash with Nef_Polyhedrons, antoine, 05/07/2012
- [cgal-discuss] Re: Crash with Nef_Polyhedrons, antoine, 05/07/2012
- [cgal-discuss] Re: Crash with Nef_Polyhedrons, antoine, 05/18/2012
- Re: [cgal-discuss] Crash with Nef_Polyhedrons, Sebastien Loriot (GeometryFactory), 05/28/2012
- [cgal-discuss] Re: Crash with Nef_Polyhedrons, antoine, 05/28/2012
- Re: [cgal-discuss] Re: Crash with Nef_Polyhedrons, Sebastien Loriot (GeometryFactory), 05/28/2012
- [cgal-discuss] Re: Crash with Nef_Polyhedrons, antoine, 05/29/2012
- Re: [cgal-discuss] Re: Crash with Nef_Polyhedrons, Sebastien Loriot (GeometryFactory), 05/29/2012
