- To:
- Subject: Re: [cgal-discuss] Toggling odt() and no_odt() and other meshing paramters
- Date: Mon, 28 May 2012 17:22:18 +0200
Le jeudi 24 mai 2012 12:15:04 slaughter a écrit :
> I am working on a meshing function based on Chapter 50 and would like to
> setup boolean flags to switch on or off the four meshing optimization
> methods given in Seciton 50.2 Interface: The global functions.
> I would like to do something like this for each of the parameters:
> if (odt_flag == true){
> Odt odt_value = CGAL::parameters::odt(); // This does't work, but is
> there something that will
> } else {
> Odt odt_value = CGAL::parameters::no_odt(); // This does't work, but is
It is documented that CGAL::parameters::odt() and CGAL::parameters::no_odt()
both return a value of type CGAL::parameters::internal::Odt but if I look in
the source code, the return type is actually
CGAL::parameters::internal::Odt_options
I will fix the documentation for next release.
Laurent Rineau, PhD
- [cgal-discuss] Toggling odt() and no_odt() and other meshing paramters, slaughter, 05/24/2012
- Re: [cgal-discuss] Toggling odt() and no_odt() and other meshing paramters, Laurent Rineau (CGAL/GeometryFactory), 05/28/2012
- [cgal-discuss] Re: Toggling odt() and no_odt() and other meshing paramters, slaughter, 05/29/2012
