cgal-discuss - [cgal-discuss] Re[2]: Finding an averaging curve though a set of points in 3D
  • To:
  • Subject: [cgal-discuss] Re[2]: Finding an averaging curve though a set of points in 3D
  • Date: Thu, 31 May 2012 03:18:39 -0700 (PDT)
That's what I'd like to do, but I'm not sure what would be the correct
syntax in this case. There is an example of using a polyline as sharp
feature for 3D mesh, but no example for surface mesh. Also, is it
possible to use the detect_features() for a surface mesh just like it
was used for 3D mesh in mesh_polyhedral_domain_with_features.cpp
example, particularly when the surface is defined by an implicit
function? Thanks for any help!
Oleg
Friday, April 27, 2012, 14:35, you wrote:
> remeshing with the polyline as sharp feature will preserve the polyline
> as it is, with no smoothing...
> One solution might be to apply a smoothing process, Laplacian
> or other convolution base process on the polyline,
> and remesh
> using the new smoother polyline as sharp features.
> Remeshing volumes and surfaces with sharp features
>   tolerate the fact that the sharp feature
> might not be exactly on the surfaces.
> Le 26/04/12 16:38, Sebastien Loriot (GeometryFactory) a écrit :
>> I read your question too fast, I thought you simply wanted to close the
>> surface.
>> There is a huge literature on mesh smoothing, but out-of-the box
>> solution is available in CGAL.
>> One thing you can try is remeshing without marking the polyline as
>> sharp feature.
>> Sebastien.
>> On 04/26/2012 03:26 PM, Oleg wrote:
>>> Hello Sebastien! Could you specify a little bit more, what you meant? It
>>> sounds interesting, but I'm not sure how the part of the other
>>> surface can
>>> help. I've tried mesh_polyhedral_domain_with_features.cpp example
>>> with the
>>> sphere and crater, but it doesn't make the edge smoother...
>>> Sebastien Loriot (GeometryFactory) wrote
>>>> You can use the part of the other surface bounded by the curve.
>>>> For example, if you have two spheres intersecting along a circle,
>>>> you'll
>>>> have a sphere with a crater.
>>>> Sebastien.
>>>> On 04/23/2012 01:40 PM, Oleg wrote:
>>>>> Hello everyone! I have a set of points in 3D as the result of
>>>>> calculating
>>>>> intersection of two triangulated 3D figures. Since they are
>>>>> calculated as
>>>>> intersection of individual triangles of the two meshes, they form a
>>>>> rather
>>>>> rough polyline. Are there any means in CGAL to smooth it over? The
>>>>> goal
>>>>> is
>>>>> to obtain a smooth sharp curve of intersection of two 3D figures.
>>>>> Oleg
>>>>> View this message in context:
>>>>> http://cgal-discuss.949826.n4.nabble.com/Finding-an-averaging-curve-though-a-set-of-points-in-3D-tp4580170p4580170.html
>>>>> Sent from the cgal-discuss mailing list archive at Nabble.com.
>>>> You are currently subscribed to cgal-discuss.
>>>> To unsubscribe or access the archives, go to
>>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
>>> http://cgal-discuss.949826.n4.nabble.com/Finding-an-averaging-curve-though-a-set-of-points-in-3D-tp4580170p4589801.html
> Mariette Yvinec
> Geometrica project team
> INRIA  Sophia-Antipolis
View this message in context: Re[2]: Finding an averaging curve though a set of points in 3D
  • [cgal-discuss] Re[2]: Finding an averaging curve though a set of points in 3D, Oleg, 05/31/2012
