Re: [cgal-discuss] triangulation - construction for TriangulationDataStructure_3
- To:
- Subject: Re: [cgal-discuss] triangulation - construction for TriangulationDataStructure_3
- Date: Mon, 11 Jun 2012 08:29:04 +0200
A Complex_3_in_Triangulation_3 is already based on a Regular
triangulation which is based on a Triangulation_data_structure_3.
You can use the copy_tds() [1] member function.
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TriangulationDS_3_ref/Concept_TriangulationDataStructure_3.html
On 06/10/2012 10:07 PM, Lukasz Kaczmarczyk wrote:
On 9 Jun 2012, at 23:39, Lukasz Kaczmarczyk wrote:
Hello,
I try to copy mesh for MOAB (MeshOrientedDatabase) into
TriangulationDataStructure_3. I hope that I could re-triangulate some ports
of it and add/move some nodes in volume. However I have some problem with
external tets and its neighbours, could you tell me how I should construct
neighbours for boundary faces?
Hello again,
I made some improvements, code is still far from prefect, after I add
additional nodes I get,
Linux,
sum of the indices != 6
MacOS X (the same code)
terminate called after throwing an instance of 'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Expr: orientation(p0, p1, p2, p3) == POSITIVE
File:
/opt/build_for_gcc-mp-4.4/CGAL-3.9/include/CGAL/Regular_triangulation_3.h
I suspect that Its something wrong with my ordering. However if I not insert
any nodes there are any complains form CGAL.
Regards,
Lukasz
void make_triangulation(Interface& moab,const EntityHandle meshset_in,const
EntityHandle meshset_out,Range&add_nodes) {
Tag th_weight;
rval = moab.tag_get_handle(RT_TRIANGULATION_WEIGHT,th_weight);
CHKERR(rval);
Rt T;
T.tds().set_dimension(3);
//cout<<"nb. cells"<<T.number_of_cells()<<endl;
//cout<<"nb. finite cells"<<T.number_of_finite_cells()<<endl;
std::vector<Weighted_point> P;
// generate points on a 3D grid
Range elems;
moab.get_entities_by_type(meshset_in,MBTET,elems);
Range moab_nodes;
moab.get_connectivity(elems,moab_nodes);
map<EntityHandle,Vertex_handle> moab_cgal_vertex_map;
for(Range::iterator moab_nit =
moab_nodes.begin();moab_nit!=moab_nodes.end();moab_nit++) {
double weigth;
rval = moab.tag_get_data(th_weight,&*moab_nit,1,&weigth); CHKERR(rval);
double coords[3];
moab.get_coords(&*moab_nit,1,coords);
Point_3_with_moab_handle p(coords,*moab_nit);
//P.push_back(Weighted_point(p,weigth));
moab_cgal_vertex_map[*moab_nit] = T.tds().create_vertex();
moab_cgal_vertex_map[*moab_nit]->set_point(Weighted_point(p,weigth));
//cout<<"nb
vertexs"<<T.tds().number_of_vertices()<<""<<moab_nodes.size()<<endl;
map<EntityHandle,Cell_handle> moab_cgal_cell_map;
for(Range::iterator moab_eit =
elems.begin();moab_eit!=elems.end();moab_eit++) {
const EntityHandle* conn;
int num_nodes;
moab.get_connectivity(*moab_eit,conn,num_nodes);
assert(num_nodes == 4);
moab_cgal_cell_map[*moab_eit] = T.tds().create_cell(
moab_cgal_vertex_map[conn[0]],
moab_cgal_vertex_map[conn[1]],
moab_cgal_vertex_map[conn[2]],
moab_cgal_vertex_map[conn[3]] );
map<EntityHandle,Cell_handle> moab_cgal_face_map;
Range skin_faces;
Skinner tool(&moab);
tool.find_skin(elems,2,skin_faces);
for(Range::iterator moab_fit =
skin_faces.begin();moab_fit!=skin_faces.end();moab_fit++) {
Range adj_elems;
moab.get_adjacencies(&*moab_fit,1,3,false,adj_elems);
assert(adj_elems.size() == 1);
const EntityHandle* conn_face;
int num_nodes;
moab.get_connectivity(*moab_fit,conn_face,num_nodes);
assert(num_nodes == 3);
const EntityHandle* conn_elem;
moab.get_connectivity(*adj_elems.begin(),conn_elem,num_nodes);
moab_cgal_face_map[*moab_fit] = T.tds().create_cell(T.infinite_cell());
for(int ii = 0;ii<4;ii++) {
int jj = ii;
if(ii == 0) jj = 1;
if(ii == 1) jj = 0;
if(find(&conn_face[0],&conn_face[3],conn_elem[ii])!=&conn_face[3]) {
moab_cgal_face_map[*moab_fit]->set_vertex(jj,moab_cgal_vertex_map[conn_elem[ii]]);
} else {
moab_cgal_face_map[*moab_fit]->set_vertex(jj,T.infinite_vertex());
moab_cgal_face_map[*moab_fit]->set_neighbor(jj,moab_cgal_cell_map[*adj_elems.begin()]);
//cout<<"nb cells"<<T.tds().number_of_cells()<<""<<elems.size()<<endl;
Range adj_elems;
moab.get_adjacencies(&*moab_nit,1,3,false,adj_elems);
moab_cgal_vertex_map[*moab_nit]->set_cell(moab_cgal_cell_map[*adj_elems.begin()]);
const int moab_cgall_cannonical_map[4] = { 1,2,0,3 };
for(int ff = 0;ff<4;ff++) {
EntityHandle face;
moab.side_element(*moab_eit,2,moab_cgall_cannonical_map[ff],face);
Range adj_elems;
moab.get_adjacencies(&face,1,3,false,adj_elems);
assert(adj_elems.size()>= 1);
assert(adj_elems.size()<= 2);
if(adj_elems.size() == 1) {
moab_cgal_cell_map[*moab_eit]->set_neighbor(ff,moab_cgal_face_map[face]);
} else {
adj_elems.erase(*moab_eit);
moab_cgal_cell_map[*moab_eit]->set_neighbor(ff,moab_cgal_cell_map[*adj_elems.begin()]);
Range adj_edges;
moab.get_adjacencies(&*moab_fit,1,1,true,adj_edges);
assert(adj_edges.size() == 3);
for(int ee = 0;ee<3;ee++) {
EntityHandle edge = adj_edges[ee];
Range adj_faces;
moab.get_adjacencies(&edge,1,2,true,adj_faces);
adj_faces = intersect(adj_faces,skin_faces);
assert(adj_faces.size()==2);
adj_faces.erase(*moab_fit);
assert(adj_faces.size()==1);
const EntityHandle* conn_edge;
int num_nodes;
moab.get_connectivity(edge,conn_edge,num_nodes);
assert(num_nodes==2);
int ii = 0;
for(;ii<4;ii++) {
if( T.is_infinite(moab_cgal_face_map[*moab_fit]->vertex(ii)) ) {
moab_cgal_face_map[*moab_fit]->vertex(ii)->set_cell(moab_cgal_face_map[*moab_fit]);
continue;
assert(moab_cgal_face_map[*moab_fit]->vertex(ii)->point().h!=(EntityHandle)-1);
if(
moab_cgal_face_map[*moab_fit]->vertex(ii)->point().h ==
conn_edge[0] ||
conn_edge[1] ) continue;
moab_cgal_face_map[*moab_fit]->set_neighbor(ii,moab_cgal_face_map[*adj_faces.begin()]);
break;
//T.tds().delete_cell(T.all_cells_begin());
//Add nodes;
add_nodes.begin();moab_nit!=add_nodes.end();moab_nit++) {
double weigth;
double coords[3];
T.insert(P.begin(),P.end());
assert( T.dimension() == 3 );
assert( T.is_valid(true) );
Rt::All_vertices_iterator cgal_vit_all = T.all_vertices_begin();
for(;cgal_vit_all!=T.all_vertices_end();++cgal_vit_all) {
//printf("aaa\n");
//if(T.is_infinite(cgal_eit_all)) printf("inf\n");
T.tds().is_valid(cgal_vit_all,true);
Rt::All_cells_iterator cgal_eit_all = T.all_cells_begin();
for(;cgal_eit_all!=T.all_cells_end();++cgal_eit_all) {
//printf("aaa\n");
T.tds().is_valid(cgal_eit_all,true);
// insert all points in a row (this is faster than one insert() at a time).
Rt::Finite_cells_iterator cgal_eit = T.finite_cells_begin();
for(;cgal_eit!=T.finite_cells_end();++cgal_eit) {
EntityHandle conn[4];
assert(cgal_eit->vertex(ii)->point().h!=(EntityHandle)-1);
conn[ii] = cgal_eit->vertex(ii)->point().h;
EntityHandle ent;
moab.create_element(MBTET,conn,4,ent);
moab.add_entities(meshset_out,&ent,1);
- [cgal-discuss] triangulation - construction for TriangulationDataStructure_3, Lukasz Kaczmarczyk, 06/10/2012
- Re: [cgal-discuss] triangulation - construction for TriangulationDataStructure_3, Lukasz Kaczmarczyk, 06/10/2012
- Re: [cgal-discuss] triangulation - construction for TriangulationDataStructure_3, Sebastien Loriot (GeometryFactory), 06/11/2012
- Re: [cgal-discuss] triangulation - construction for TriangulationDataStructure_3, Lukasz Kaczmarczyk, 06/11/2012
