- To:
- Subject: Re: [cgal-discuss] polyhedron to nef-polyhedron conversion error
- Date: Mon, 11 Jun 2012 15:44:56 +0200
You have either degenerate faces (0-area facets) or facets that are
made of more than 3 points that do not *exactly* lie in a plane.
Sebastien.
On 06/11/2012 03:40 PM, Luis wrote:
Hi,
I am trying to convert polydrons from off files into nef-polydrons.
When I am compiling I get the following errors:
Error !!!!!!!!!!!!!!!!!!!!!!!
CGAL error: assertion violation!
Expression : pe_prev->is_border() || !
internal::Plane_constructor<Plane>::get_pl
ane(pe_prev->facet(),pe_prev->facet()->plane()).is_degenerate()
File : c:\program files\cgal-3.9\include\cgal
\nef_3\polyhedron_3_to_nef_3.
h
Line : 252
Explanation:
Refer to the bug-reporting instructions at http://www.cgal.org/bug_report.html
found an exception! BldgElem__1919.off
Expression : e->incident_sface() != SFace_const_handle()
\nef_s2\sm_const_decorator.h
Line : 319
Explanation:
found an exception! BldgElem__42.off
h
Line : 252
Explanation:
found an exception! BldgElem__484.off
h
Line : 252
Explanation:
found an exception! BldgElem__563.off
Line : 319
Explanation:
found an exception! BldgElem__570.off
Line : 319
Explanation:
found an exception! BldgElem__572.off
Line : 319
Explanation:
found an exception! BldgElem__573.off
Line : 319
Explanation:
found an exception! BldgElem__603.off
Line : 319
Explanation:
found an exception! BldgElem__605.off
Line : 319
Explanation:
found an exception! BldgElem__646.off
Line : 319
Explanation:
found an exception! BldgElem__649.off
I believe the problem is when changing from polyhedron to nef-polyhedron, any
help works great, thank you.
Luis Rodriguez
- [cgal-discuss] polyhedron to nef-polyhedron conversion error, Luis, 06/11/2012
- Re: [cgal-discuss] polyhedron to nef-polyhedron conversion error, Sebastien Loriot (GeometryFactory), 06/11/2012
- Re: [cgal-discuss] polyhedron to nef-polyhedron conversion error, Luis Rodriguez, 06/11/2012
