- To:
- Subject: Re: [cgal-discuss] Re: Slhouette: From 3d to 2d
- Date: Wed, 13 Jun 2012 00:35:30 +0200
Oops. My bad.
2012/6/12 Efi Fogel <>
when you encounter a problem like this, run the program in debug mode first.
Secondly, if you had read the book, you would have known that the program takes a direction as a mandatory argument. Try the following:
./polyhedron_projection 0 0 1 hand.off--On Tue, Jun 12, 2012 at 1:56 PM, noel <> wrote:
Goodness the thread is half a year old already. Some stuff happened to me
that pulled me away from CGAL. Anyway, that book looks amazing. Tons of
useful examples. I downloaded the polyhedron projection example and
compiled it. When I run the executable I get the following error
noel@vistii1:~/Downloads/examples/chapter_8$ ./polyhedron_projection
Segmentation fault
Very uninformative error. Any ideas?
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Slhouette-From-3d-to-2d-tp4352895p4655203.html
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- [cgal-discuss] Re: Slhouette: From 3d to 2d, noel, 06/12/2012
- Re: [cgal-discuss] Re: Slhouette: From 3d to 2d, Efi Fogel, 06/12/2012
- Re: [cgal-discuss] Re: Slhouette: From 3d to 2d, Noel Warren, 06/13/2012
