- To:
- Subject: Re: [cgal-discuss] Nef_polyhedron : intersection and volume
- Date: Tue, 19 Jun 2012 19:46:53 +0200
An easy solution is to convert each Polyhedron_3 to a Nef_polyhedron
and then subtract it from your polyhedron.
Sebastien.
On 06/19/2012 05:55 PM, Tomislav Maric wrote:
Hi everyone,
can I intersect a Nef_polyhedron with a set of Polyhedron_3 facets, and
compute
the resulting volume? Will this work regardless of the composition of
faces?
I have attached a picture: the Polyhedron_3 is used as a surface mesh,
the bounding
box heuristic intersection test would be used to find the face sets that
intersect each
Nef_polyhedron, after which I would execute the intersection. Is this
the way to
calculate the blue shaded volume on the attached picture?
Thanks,
Tomislav
- [cgal-discuss] Nef_polyhedron : intersection and volume, Tomislav Maric, 06/19/2012
- Re: [cgal-discuss] Nef_polyhedron : intersection and volume, Sebastien Loriot (GeometryFactory), 06/19/2012
- Re: [cgal-discuss] Nef_polyhedron : intersection and volume, Tomislav Maric, 06/20/2012
- Re: [cgal-discuss] Nef_polyhedron : intersection and volume, Sebastien Loriot (GeometryFactory), 06/20/2012
