- To:
- Subject: [cgal-discuss] Intersections with a Nef_polyhedron_3
- Date: Thu, 28 Jun 2012 17:19:05 +0200
Hi all,
I am trying to figure out how to test the intersection (and retrieve the result of intersection as a second step) between some primitives and a Nef_polyhedron_3.
If I want to test the intersection with a >=2-dimension primitive, I think a good way is to build a Polyhedron_3 from that primitive and substract it from the Nef_polyhedron.
But what about points and lines ?
About points, there is a locate( Point_3 ) method, but I cannot figure out how to know if the resulting volume is the bounded one (my nef_polyhedron) or the unbounded "outter" volume (A similar question has been asked some time ago on this list without answer).
About line segments, I cannot rely on the point test, since a line segment can intersects a volume, but not its two vertices.
I am currently thinking of converting the Nef_polyhedron to a Polyhedron (If I understand correctly, it is done using triangulation underneath, right ?) and use intersection tests between Segment_3 and Triangle_3 for the "naive" option and AABB trees for something more efficient.
Is there a more "direct" way to do that with CGAL ?
Hugo Mercier
Oslandia
- [cgal-discuss] Intersections with a Nef_polyhedron_3, Hugo Mercier, 06/28/2012
- Re: [cgal-discuss] Intersections with a Nef_polyhedron_3, Sebastien Loriot (GeometryFactory), 06/29/2012
