- To:
- Cc: cgal-discuss <>
- Subject: Re: [cgal-discuss] Problem customizing Polyhedron_3 Point type
- Date: Fri, 29 Jun 2012 10:27:50 +0200
David Coeurjolly
writes:
> Dear cgal-discuss,
> I'm having issues with a customization of CGAL Polyhedron_3 and after
> discussing about that with couple of CGAL gurus, I'm posting my problem
> here.
> I would like to construct a Polyhedron_3 upon a specific point class (not a
> custom vertex class via wrappers). More precisely, I would like to use
> Weighted_point class which decorated a template class point with "weights"
> (note: Weighted_Point inherits from the given class Point). Hence, my new
> class of points satisfies with the point concept and many of the
> methods/functions dealing with points can use the weighted points....
> except Polyherdon_3...
> More precisely, I'm doing something like that:
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> struct My_items : public CGAL::Polyhedron_items_3
> template <class Refs, class Traits>
> struct Vertex_wrapper {
> typedef CGAL::Weighted_point<typename Traits::Point_3, double> Point;
> //CustomPoints
> typedef CGAL::HalfedgeDS_vertex_base<Refs,CGAL::Tag_true,Point> Vertex;
> template < class Refs, class Traits>
> struct Halfedge_wrapper {
> typedef CGAL::HalfedgeDS_halfedge_base<Refs>
> Halfedge;
> struct Face_wrapper {
> typedef typename Traits::Plane_3 Plane;
> typedef CGAL::HalfedgeDS_face_base<Refs, CGAL::Tag_true, Plane> Face;
> typedef CGAL::Polyhedron_3<K, My_items > Polyhedron_3;
> but when I want to use it (for example to compute the convex hull of
> weighted point considering only the point coordinates), I get an
> compilation error in the Polyhedron_3 class (not matching function
> ‘CGAL::HalfedgeDS_in_place_list_vertex<...) which seems to be related to
> Halfedge containers. Note: for the rest of the process, I really need the
> weights to be associated with the points and not the polyhedron 3
> vertices...
> Am I doing something wrong ? How can I customize the Point class in
> Polyhedron ?
Can you try to give a minimal example that fails to compile (all
includes, a main that triggers instantiation), the full error output and
the CGAL version you are using? A compiler version would be helpful as
well.
Thanks,
Philipp
- [cgal-discuss] Problem customizing Polyhedron_3 Point type, David Coeurjolly, 06/29/2012
- Re: [cgal-discuss] Problem customizing Polyhedron_3 Point type, Laurent Rineau (CGAL/GeometryFactory), 06/29/2012
- Re: [cgal-discuss] Problem customizing Polyhedron_3 Point type, Philipp Moeller, 06/29/2012
