- To:
- Subject: Re: [cgal-discuss] Get the overlapped face info for multiple arrangements
- Date: Tue, 03 Jul 2012 08:43:17 -0400
Hi Y'all,
Assuming "efficient" means lowest time complexity, overlay is best for the general case.
The only exception I found: if one arrangement has a much larger number of half-edges than the other _and_ you can accept that the first arrangement be altered, it's quicker to insert the second arrangement's edges into the first and rebuild the face information.
But the difference in size has to be _really extreme_, and if the size difference really is extreme the edges have to be inserted individually (because the bulk edge inserted is going to do something quite similar to a full overlay).
I hit this case when intersecting a single polygon (with perhaps 20 or 30 sides) into an arrangement with on the order of a million edges.
For two large arrangements "overlay" is really quite good!!
cheers
Ben
On 7/3/12 3:51 AM, Efi Fogel wrote:
On Tue, Jul 3, 2012 at 10:34 AM, Graviton
<mailto:>>
wrote:
I have a number of
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Arrangement_2/Chapter_main.html
arrangements with vertices v, edges e and faces f. I tag each face
in each
of the arrangement properly (e,g, {A} face means that the face is
inside the
arrangement A)
Now, I want to overlay all these arrangements together, and for the
resulting arrangement, I want each face will have a tag of the original
arrangements. How to do this? My idea is that I want to use
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Arrangement_2_ref/Function_overlay.html#Cross_link_anchor_811
overlay function for the first two arrangements to find a resulting
arrangement, and use the overlay on the resulting arrangement and third
arrangements, and so on.
But do we have a more efficient way of working?
No.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Get-the-overlapped-face-info-for-multiple-arrangements-tp4655345.html
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://www.x-plane.com/blog/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] Get the overlapped face info for multiple arrangements, Graviton, 07/03/2012
- Re: [cgal-discuss] Get the overlapped face info for multiple arrangements, Victor Lopez, 07/03/2012
- Re: [cgal-discuss] Get the overlapped face info for multiple arrangements, Efi Fogel, 07/03/2012
- Re: [cgal-discuss] Get the overlapped face info for multiple arrangements, Ben Supnik, 07/03/2012
- [cgal-discuss] Re: Get the overlapped face info for multiple arrangements, Graviton, 07/03/2012
- Re: [cgal-discuss] Re: Get the overlapped face info for multiple arrangements, Ben Supnik, 07/03/2012
