cgal-discuss - Re: [cgal-discuss] Re: Get the overlapped face info for multiple arrangements
  • To:
  • Subject: Re: [cgal-discuss] Re: Get the overlapped face info for multiple arrangements
  • Date: Tue, 03 Jul 2012 08:58:35 -0400
I am not sure. My original point was only that overlay is not good for the very rare case where one of the arrangements is trivial and the other is huge.
For multiple general arrangements, it might be faster to merge several at once, but as far as I know CGAL doesn't provide that "off the shelf"; the boolean operations code can do it - it "overlays" 5 (by default) arrangements at once - if given 10 it "overlays" 5 and 5 and then overlays the results.
But to get that for the general overlay case you'd have to write your own sweep visitor, which is quite complex (unless CGAL added this and I missed it) so perhaps overlay and then overlay the results (for log 2 overlays) is best.
cheers
Ben
On 7/3/12 8:47 AM, Graviton wrote:
Thanks Ben, are you saying that by overlaying one arrangement with
another, and get the resulting arrangement to overlay with another
arrangement, and repeat this until the very last arrangement, this is
the best algorithm for my use case?
On Tue, Jul 3, 2012 at 8:44 PM, Ben Supnik [via cgal-discuss] <[hidden
email] </user/SendEmail.jtp?type=node&node=4655349&i=0>> wrote:
Hi Y'all,
Assuming "efficient" means lowest time complexity, overlay is best for
the general case.
The only exception I found: if one arrangement has a much larger number
of half-edges than the other _and_ you can accept that the first
arrangement be altered, it's quicker to insert the second arrangement's
edges into the first and rebuild the face information.
But the difference in size has to be _really extreme_, and if the size
difference really is extreme the edges have to be inserted individually
(because the bulk edge inserted is going to do something quite similar
to a full overlay).
I hit this case when intersecting a single polygon (with perhaps 20 or
30 sides) into an arrangement with on the order of a million edges.
For two large arrangements "overlay" is really quite good!!
cheers
Ben
On 7/3/12 3:51 AM, Efi Fogel wrote:
> On Tue, Jul 3, 2012 at 10:34 AM, Graviton <[hidden email]
<http://user/SendEmail.jtp?type=node&node=4655348&i=0>
> < email]
<http://user/SendEmail.jtp?type=node&node=4655348&i=1>>> wrote:
> I have a number of
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Arrangement_2/Chapter_main.html
> arrangements with vertices v, edges e and faces f. I tag
each face
> in each
> of the arrangement properly (e,g, {A} face means that the
face is
> inside the
> arrangement A)
> Now, I want to overlay all these arrangements together, and
for the
> resulting arrangement, I want each face will have a tag of
the original
> arrangements. How to do this? My idea is that I want to use
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Arrangement_2_ref/Function_overlay.html#Cross_link_anchor_811
> overlay function for the first two arrangements to find a
resulting
> arrangement, and use the overlay on the resulting arrangement
and third
> arrangements, and so on.
> But do we have a more efficient way of working?
> No.
> View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Get-the-overlapped-face-info-for-multiple-arrangements-tp4655345.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> ____ _ ____ _
> /_____/_) o /__________ __ //
> (____ ( ( ( (_/ (_/-(-'_(/
> _/
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://www.x-plane.com/blog/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list: [hidden email]
<http://user/SendEmail.jtp?type=node&node=4655348&i=2>
Developer mailing list: [hidden email]
<http://user/SendEmail.jtp?type=node&node=4655348&i=3>
If you reply to this email, your message will be added to the
discussion below:
http://cgal-discuss.949826.n4.nabble.com/Get-the-overlapped-face-info-for-multiple-arrangements-tp4655345p4655348.html
To unsubscribe from Get the overlapped face info for multiple
arrangements, click here.
NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: Get the overlapped face info for
<http://cgal-discuss.949826.n4.nabble.com/Get-the-overlapped-face-info-for-multiple-arrangements-tp4655345p4655349.html>
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
