- To:
- Subject: [cgal-discuss] Re: General_Polygon_with_holes_2 not valid
- Date: Wed, 4 Jul 2012 23:29:34 -0700 (PDT)
if one of the vertex from the hole is out of the outer bounday just a little,
is there any method to solve this? I got the point data from AutoCAD, and I
believe the data precision in AutoCAD is much lower than in CGAL. in
AutoCAD, the vertex is on one line,but construct them using CGAL's point and
line, then test and found the point is not the line.
technology change life!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/General-Polygon-with-holes-2-not-valid-tp4655366p4655370.html
- [cgal-discuss] General_Polygon_with_holes_2 not valid, cnng0315, 07/05/2012
- Re: [cgal-discuss] General_Polygon_with_holes_2 not valid, Sebastien Loriot (GeometryFactory), 07/05/2012
- [cgal-discuss] Re: General_Polygon_with_holes_2 not valid, cnng0315, 07/05/2012
- Re: [cgal-discuss] Re: General_Polygon_with_holes_2 not valid, Sebastien Loriot (GeometryFactory), 07/05/2012
