- To:
- Subject: Re: [cgal-discuss] Re: Tetrahedral mesh point location
- Date: Fri, 06 Jul 2012 16:34:34 +0200
I meant to work directly with tetrahedra.
You need a new model of AABBTraits:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/AABB_tree_ref/Concept_AABBTraits.html
with a new model of AABBPrimitive:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/AABB_tree_ref/Concept_AABBPrimitive.html
Sebastien.
On 07/06/2012 04:29 PM, Zohar wrote:
I'm not sure about the type, these are tets from a triangular mesh that were
generated with TetGen.
AABB tree solution sounds excellent, but I'm not sure how to go about it. Is
there some example for a custom type other than a triangle
(AABB_custom_example.cpp converts a custom triangle to cgal's triangle)?
Or did you mean that I would simply check intersection of a tet faces with
the point? But then I would need to intersect the point with at every
triangle twice.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Tetrahedral-mesh-point-location-tp4655387p4655390.html
- [cgal-discuss] Tetrahedral mesh point location, Zohar, 07/06/2012
- Re: [cgal-discuss] Tetrahedral mesh point location, Sebastien Loriot (GeometryFactory), 07/06/2012
- [cgal-discuss] Re: Tetrahedral mesh point location, Zohar, 07/06/2012
- Re: [cgal-discuss] Re: Tetrahedral mesh point location, Sebastien Loriot (GeometryFactory), 07/06/2012
- [cgal-discuss] Re: Tetrahedral mesh point location, Zohar, 07/07/2012
- Re: [cgal-discuss] Re: Tetrahedral mesh point location, Mariette Yvinec, 07/09/2012
- [cgal-discuss] Re: Tetrahedral mesh point location, Zohar, 07/09/2012
