Re: [cgal-discuss] Straight skeleton with Exact_predicates_exact_constructions_kernel
- To:
- Subject: Re: [cgal-discuss] Straight skeleton with Exact_predicates_exact_constructions_kernel
- Date: Tue, 10 Jul 2012 12:28:37 +0200
Thank you very much, it worked when I supply the kernel to the function.
Have a nice day
Murat
2012/7/10 Philipp Moeller
> Myirci
> writes:
>> Dear all,
>> I'm trying to generate a straight skeleton of a simple polygon using
>> CGAL version 3.8. I built and ran the example given below.
>> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Straight_skeleton_2/Chapter_main.html
>> - "23.3.1 Create a Straight Skeleton"
>> However I need to use the Exact_predicates_exact_constructions_kernel.
>> In all of the examples given in the CGAL Documentation
>> Exact_predicates_inexact_constructions_kernel is used.
> Look at the documentation of the function
> CGAL::create_interior_straight_skeleton_2 [1]. The third parameter of
> the overload used in the example lets you specify the kernel that is to
> be used for the return Straight_skeleton.
> It's a little bit odd that the parameter is not chosen depending on the
> input primitives, but has to be manually specified.
> Also, you are linking to the CGAL 4.0 documentation. Be careful to use
> the right documentation for the version you are using.
> HTH,
> Philipp
> Footnotes:
> [1]
> http://www.cgal.org/Manual/3.8/doc_html/cgal_manual/Straight_skeleton_2_ref/Function_create_interior_straight_skeleton_2.html
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Straight skeleton with Exact_predicates_exact_constructions_kernel, Myirci, 07/10/2012
- Re: [cgal-discuss] Straight skeleton with Exact_predicates_exact_constructions_kernel, Sebastien Loriot (GeometryFactory), 07/10/2012
- Re: [cgal-discuss] Straight skeleton with Exact_predicates_exact_constructions_kernel, Philipp Moeller, 07/10/2012
- Re: [cgal-discuss] Straight skeleton with Exact_predicates_exact_constructions_kernel, Myirci, 07/10/2012
