- To:
- Subject: [cgal-discuss] Re: How to use CGAL Libs in VS2010 C++/C#?
- Date: Tue, 10 Jul 2012 16:11:19 -0700 (PDT)
Hi Mailang,
.net code cannot use C++ classes that uses templates directly. You must
instantiate the template using another C++ that implements the template.
Your .NET code can call this C++ class.
Anyway, this is not a CGAL specific problem. Perhaps, you should perform
your question in other C++ forums. The developers at www.codeproject.com
forum know well .net code and the way of joining with C++ code. Make your
question to them. Ask for the way of joining .net code with C++ template
classes.
Regards.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-use-CGAL-Libs-in-VS2010-C-C-tp4655418p4655421.html
- [cgal-discuss] How to use CGAL Libs in VS2010 C++/C#?, 马良, 07/10/2012
- [cgal-discuss] Re: How to use CGAL Libs in VS2010 C++/C#?, JuanLu, 07/11/2012
