- To:
- Subject: [cgal-discuss] anyone give me an expample of snap_rounding with custom point
- Date: Fri, 13 Jul 2012 20:45:59 -0700 (PDT)
I would like to add some extra info to point, so I derived from CGAL::Point_2
like the code below. but with the custom point, the snap_rounding algorithm
gives error result compared with the standard point.
template<class Gt,typename Info>
class Point_With_Info : public Gt::Point_2
// Private types
private:
typedef typename Gt::Point_2 Base;
// Public types
public:
typedef Gt Geom_traits; ///< Geometric traits class
typedef typename Geom_traits::FT FT;
typedef typename Geom_traits::RT RT;
typedef typename Geom_traits::Point_2 Point; ///< typedef to
Geom_traits::Point_3
// Public methods
public:
/// Point is (0,0,0) by default.
/// Normal is (0,0,0) by default.
Point_With_Info()
: Base()
Point_With_Info(FT x, FT y)
: Base(x,y)
Point_With_Info(FT x, FT y,const Info& tmp)
: Base(x,y),info(tmp)
//Point_With_Info(RT hx, RT hy)
// : Base(hx,hy)
Point_With_Info(const Point& point,const Info& tmp)
: Base(point),info(tmp)
Point_With_Info(const Point& point)
: Base(point)
/// Copy constructor
Point_With_Info(const Point_With_Info& pwn)
: Base(pwn),info(pwn.info)
template <class K,typename Info>
Point_With_Info(const Point_With_Info<K,Info>& pwn)
/// Operator =()
Point_With_Info& operator=(const Point_With_Info& pwn)
Base::operator=(pwn);
info = pwn.info;
return *this;
/// Gets/sets position.
const Point& position() const { return *this; }
Point& position() { return *this; }
// Data
Info info;
technology change life!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/anyone-give-me-an-expample-of-snap-rounding-with-custom-point-tp4655450.html
- [cgal-discuss] anyone give me an expample of snap_rounding with custom point, cnng0315, 07/14/2012
- Re: [cgal-discuss] anyone give me an expample of snap_rounding with custom point, Efi Fogel, 07/14/2012
