- To:
- Cc: Zohar <>,
- Subject: Re: [cgal-discuss] Re: 3D mesh generation random result
- Date: Mon, 16 Jul 2012 11:08:56 +0200
Hi,
refinement starts with a random process that picks random points on the input surface.
If you want to seed this process and make it deterministic, you should add this :
CGAL::default_random = CGAL::Random(0);
before make_mesh_3
best,
Jane.
Le 15/07/2012 19:07, Zohar a écrit :
No, it didn't work, and it's disabled by default according to the doc. I
also tried:
parameters::no_lloyd(),
parameters::no_odt(),
parameters::no_perturb(),
parameters::no_exude()
but to no avail.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-mesh-generation-random-result-tp4655452p4655459.html
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] 3D mesh generation random result, Zohar, 07/14/2012
- Re: [cgal-discuss] 3D mesh generation random result, Sebastien Loriot (GeometryFactory), 07/14/2012
- [cgal-discuss] Re: 3D mesh generation random result, Zohar, 07/15/2012
- Re: [cgal-discuss] Re: 3D mesh generation random result, Jane Tournois, 07/16/2012
- [cgal-discuss] Re: 3D mesh generation random result, Zohar, 07/17/2012
