cgal-discuss - Re: [cgal-discuss] Neighbours of an infinite cell
  • To:
  • Subject: Re: [cgal-discuss] Neighbours of an infinite cell
  • Date: Wed, 18 Jul 2012 18:49:20 +0200
Hi,
[Reminder: is the up-to-date address for this mailing list.
It replaced the old
* Each facet p,q,r of the convex hull is
- the finite facet of an infinite cell p,q,r,inf
- one of the facets of a finite cell p,q,r,s
These two cells must be neighbors in the data structure.
You must be very careful with orientation (see Sec 39.1)
* When two facets p,q,r and p,q,s of the convex hull share a common edge p,q, then their respective infinite cells p,q,r,inf and p,q,s,inf are neighbors through a common facet p,q,inf.
Here again, be careful with orientation.
In fact, it is easier (and safer) to just read the vertices of your external triangulation, and construct a CGAL triangulation from scratch by inserting the corresponding points...
Best,
Monique Teillaud
Le 18/07/12 17:56, Simon Perkins a écrit :
Hello
I'm writing a loader that will read information from an external file
format into the CGAL Triangulation_3 data structure. One thing that may
be problematic is that the file format doesn't explicitly define the
infinite cells intrinsic to CGAL's representation and so I will have to
create them myself. I don't find this too daunting but I'm not sure how
the neighbours of an infinite cell should be configured. It seems clear
to me that the one can set the neighbour of the infinite vertex to be
the finite cell sharing a facet with the infinite cell, but I'm not sure
how to handle the neighbours of the other three vertices on the facet
itself.
Would it be valid to set them to a random finite cell for example?
kind regards
Simon
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
