cgal-discuss - Re: [cgal-discuss] Re: least distance between two points on a sphere
  • To:
  • Subject: Re: [cgal-discuss] Re: least distance between two points on a sphere
  • Date: Wed, 25 Jul 2012 11:13:53 +0200
Le 25/07/12 11:02, Monique Teillaud a écrit :
Le 25/07/12 10:57, cnng0315 a écrit :
sorry , I searched the whole directory of CGAL 4.0, but found no file
contains "ComputeApproximateSquaredLength_3 ", can you give me the exact
kernel that has "ComputeApproximateSquaredLength_3 "?
The information was written in my previous message already...
Here it is again
use the CGAL 3D Spherical Geometry Kernel
in particular SphericalKernel::ComputeApproximateSquaredLength_3
Looking at files is something, but reading the manual usually helps
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/contents.html
part IV, chapter 14
Actually, you have no chance to find ComputeApproximateSquaredLength_3 by grepping the source code files, since it is the name of a concept.
But if you read the manual, you will see that
CGAL::Spherical_kernel_3 is a model of SphericalKernel
Then you should normally find that
SphericalKernel::Compute_approximate_squared_length_3
is a model of SphericalKernel::ComputeApproximateSquaredLength_3.
But there is a bug in the manual, since it is written
instead of
I am going to fix this, it will be corrected in the next CGAL release.
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
