- To:
- Subject: [cgal-discuss] Beginner: 3D Booleans on Nef Polyhedra (Union)
- Date: Wed, 25 Jul 2012 11:02:03 -0700 (PDT)
Hi,
I have tried to merge several .off files (i generated) together into one
.off file.
This works really good, but some meshes are giving me headaches.
I am using the CGAL::Exact_predicates_exact_constructions_kernel.
I think it fails because these meshes are adjacent to another, having
faces/vertices that are (almost) the same.
so it becomes non-manifold in some cases. (even though it shouldn't)
Nevertheless, is there a way to export non.manifold Nef polyhedra to .off
format?
i always convert them to normal polyhedra and export these. And there is the
problem with the non-manifoldness.
I have extracted 2 simple meshes where this problem occurs.
I can send these to you when you decide to take on my problem.
Thanks,
Cheers René
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Beginner-3D-Booleans-on-Nef-Polyhedra-Union-tp4655576.html
- [cgal-discuss] Beginner: 3D Booleans on Nef Polyhedra (Union), menrix, 07/25/2012
