- To:
- Subject: [cgal-discuss] Detect delaunay 2d vertex remove changes
- Date: Thu, 26 Jul 2012 03:48:59 -0700 (PDT)
Hey Guy,
which is the most efficient way to detect the change when i remove a vertex
from a delaunay 2d trangulation. Currently i use this implementation:
std::vector<Vertex_handle> incident_vertices;
Vertex_circulator vertex_circ =
delaunay_terrain->incident_vertices(vertex);
Vertex_circulator vertex_circ_end = vertex_circ;
CGAL_For_all(vertex_circ,vertex_circ_end)
incident_vertices.push_back(vertex_circ);
delaunay_terrain->remove(vertex);
Face_circulator incident_faces_circ = NULL;
Face_circulator incident_faces_circ_end = NULL;
for(int i=0;i<incident_vertices.size();i++)
delaunay_terrain->incident_faces(incident_vertices[i]);
incident_faces_circ_end = incident_faces_circ;
CGAL_For_all(incident_faces_circ,incident_faces_circ_end)
Face_handle actual_new_face = incident_faces_circ;
[..] --> store new faces here
Any idea for improvement?
Thanks! =)
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Detect-delaunay-2d-vertex-remove-changes-tp4655589.html
- [cgal-discuss] Detect delaunay 2d vertex remove changes, Op3rAtor, 07/26/2012
- Re: [cgal-discuss] Detect delaunay 2d vertex remove changes, Mariette Yvinec, 07/26/2012
