- To:
- Subject: Re: Re: [cgal-discuss] Static vs Shared
- Date: Thu, 26 Jul 2012 12:47:17 -0400
It might worth mentioning that in the RedHat machine CGAL is actually
"make installed", while in the ubuntu machine CGAL is merely "made".
Regards,
Panagiotis
On Thu, Jul 26, 2012 at 7:26 AM, Panagiotis Foteinos
wrote:
> Sure.
> For Ubuntu: cmake version 2.8.8
> For RedHat: cmake version 2.8.4
> On Thu, Jul 26, 2012 at 7:02 AM, Laurent Rineau (CGAL/GeometryFactory)
> wrote:
>> Le jeudi 26 juillet 2012 06:49:17 Panagiotis Foteinos a écrit :
>>> BUILD_SHARED_LIBS is set to OFF during the configuration.
>>> Variable CGAL_BUILD_SHARED_LIBS is also OFF inside CGALConfig.cmake
>>> I repeat that only .a libraries are generated, as it ought to be. My
>>> project, however, is searching for shared libraries.
>>> Anyhow, it seems that the problem appears only in RedHat, since in
>>> Ubuntu I had no problem.
>> It looks like a bug in CMake. Can you tell us which versions of CMake are
>> installed on the Ubuntu and RedHat distribution you use?
>> Laurent Rineau, PhD
>> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
>> Release Manager of the CGAL Project http://www.cgal.org/
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/20/2012
- Re: [cgal-discuss] Static vs Shared, Jakob van Bethlehem, 07/23/2012
- Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/23/2012
- Re: [cgal-discuss] Static vs Shared, Sebastien Loriot (GeometryFactory), 07/25/2012
- Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/25/2012
- Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/26/2012
- Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/26/2012
- Re: Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/26/2012
- Re: Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/26/2012
- Re: Re: Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/27/2012
- Re: Re: Re: Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/27/2012
