cgal-discuss - [cgal-discuss] Dangling vertices in output of make_surface_mesh
  • To:
  • Subject: [cgal-discuss] Dangling vertices in output of make_surface_mesh
  • Date: Thu, 26 Jul 2012 17:25:33 -0400
Hi,
I'm using make_surface_mesh to build a mesh from an isosurface. The resulting mesh looks good, but appears to have "dangling" vertices, i.e. vertices not part of any face.
I'm using the Manifold_tag, my model is a single connected component, and bounding box appears correctly initialized. Apart from those dangling vertices, the mesh appears properly connected and well formed.
Is that the expected behavior of the function? And if not, any ideas on what could be the cause of this?
Thanks,
Catherine
  • [cgal-discuss] Dangling vertices in output of make_surface_mesh, Catherine Proulx, 07/26/2012
