cgal-discuss - Re: [cgal-discuss] problem with CGAL and CMAKE - mostly SOLVED
  • To:
  • Cc: Anthony Truchet <>
  • Subject: Re: [cgal-discuss] problem with CGAL and CMAKE - mostly SOLVED
  • Date: Thu, 02 Aug 2012 15:26:57 +0200
On 8/2/12 3:05 PM, Anthony Truchet wrote:
Le 02/08/2012 13:15, Laurent Rineau (CGAL/GeometryFactory) a écrit :
Le jeudi 02 août 2012 11:36:37 anthony a écrit :
I suspect so-called auto-link feature is implied because it does no make
sense (at least to me for now) to freeze in the
lib/CGAL/CGALConfig.cmake
file the kind of compilation option the clinet project will use...
I'm very willing to contribute a patch but I would need some help
from CGAL
/ CMake gurus to do so. Thanks.
Indeed on Windows, when MSVC is used, the CGAL*LIBRARY variables are
empty, on
purpose, because the auto-linking i used.
Thanks for this quick answer. But how come then that those variables are
used, resulting in so many errors ? Is it on CGAL side on the client
projet side ? I would have expected that the UseCGAL.cmake would do
"what is required".
Can you point out the positions where it is used? And the errors?
By the way could you please point me to where the autolink feature is
implemented / documented so that I can understand it better and
hopefully fix those annpying messages ?
Anthony Truchet
