- To:
- Subject: Re: [cgal-discuss] Convert Polyhedron_3 to Mesh_polyhedron_3
- Date: Fri, 03 Aug 2012 11:41:41 +0200
Le jeudi 02 août 2012 05:59:35 ju21 a écrit :
> Hello,
> I'm a new CGAL developper and I'd like to know if it's possible to convert a
> *Polyhedron_3* to a *Mesh_polyhedron_3* ?
> And if it's not a problem how could I do that ?
One can do that using the incremental builder.
There is a file <CGAL/Polyhedron_copy.h>, that can also help you. It is not
used for a long time in CGAL. There is a typo in it. Line 52:
typedef typename HDS::Point Point;
it should be:
typedef typename HDS::Vertex::Point Point;
Once that is fixed, you can do:
Polyhedron polyhedron;
Mesh_polyhedron new_polyhedron;
typedef CGAL::Polyhedron_copy_3<Polyhedron, Mesh_polyhedron::HDS> Poly_copy;
Poly_copy polyhedron_copy_modifier(polyhedron);
new_polyhedron.delegate(polyhedron_copy_modifier);
The last line will copy 'polyhedron' to 'new_polyhedron'.
Laurent Rineau, PhD
- [cgal-discuss] Convert Polyhedron_3 to Mesh_polyhedron_3, ju21, 08/02/2012
- Re: [cgal-discuss] Convert Polyhedron_3 to Mesh_polyhedron_3, Laurent Rineau (CGAL/GeometryFactory), 08/03/2012
- [cgal-discuss] Re: Convert Polyhedron_3 to Mesh_polyhedron_3, ju21, 08/03/2012
