- To:
- Subject: [cgal-discuss] Re: Problem with make_mesh_3
- Date: Fri, 3 Aug 2012 03:11:06 -0700 (PDT)
Laurent Rineau (CGAL/GeometryFactory) wrote
> Actually that is a big bug in the documentation of the requirements of
> CGAL::Polyhedral_mesh_domain_with_features_3. The polyhedron type that is
> used
> must use the items class template that is in the file
> <CGAL/Mesh_polyhedron_3.h>. The easiest way to satisfy those
> requirements is
> to use CGAL::Mesh_polyhedron_3<K>::type as polyhedron type.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
Yes, I saw this way yesterday.
So I use *Mesh_polyhedral_3* to construct the domain. But I really need to
use *Polyhedron_3* to start by converting the original mesh into a CGAL
object (in fact the user builds a mesh and I can convert it into a
*Polyhedron_3*)
So do you know a way to convert *Polyhedron_3* into *Mesh_polyhedron_3* ?
I don't really know if it's possible (I open a topic about that) but I hope
it is.
Thank you
Julie
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-make-mesh-3-tp4655492p4655650.html
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 08/01/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Laurent Rineau (CGAL/GeometryFactory), 08/03/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 08/03/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 08/08/2012
