cgal-discuss - Re: [cgal-discuss] Message distribution: Authorization denied
  • To: cgal-discuss <>
  • Subject: Re: [cgal-discuss] Message distribution: Authorization denied
  • Date: Fri, 03 Aug 2012 15:33 +0200
Le vendredi 03 août 2012 13:54:51 Ines a écrit :
> Hello verybody!
> I have a problem to build cgal.
> I downloaded CGAL-4.0.2-Setup.exe and installed it. Boost (1.50.0) and
> zlib (1.27) were installed before. After that I ran cmake for VS2010
> 64bit on Windows 7. I see no mistake in the cmake output text. The
> cgal.sln is created and I run it on VS2010 x64. If I build CGAL, errors
> occur.
> - error C2039: 'exit': Is not an element of 'std' C:\Program Files
> (x86)\CGAL-4.0.2\src\CGAL\assertions.cpp - error C3861: "exit": Identifier
> was not found. C:\Program Files (x86)\CGAL-4.0.2\src\CGAL\assertions.cpp
> - IntelliSense: "namespace "std"" have no member ""exit"". c:\program
> files (x86)\cgal-4.0.2\src\cgal\assertions.cpp
Are those the first errors or the compilation? That is strange because
CGAL-4.0.2\src\CGAL\assertions.cpp includes <cstdlib>, and that header does
define std::exit.
Laurent Rineau, PhD
